What Can Handle Hot Water Expansion? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2012, 10:17 PM   #16
Rewards Points: 582
Originally Posted by Plumber101 View Post
Already did that
sorry Ishould read better before speaking...thanks
Old 02-05-2012, 10:20 PM   #17
GC/Master Plumber/Mech
Rewards Points: 560
No biggie ben
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-06-2012, 12:45 PM   #18
Rewards Points: 1,452
What is the pressure gauge reading at around the time the water heater pressure/temp relief valve trips?
Could there be a check valve in the water softener so pressure downstream is not relieved via the blue pressure tank?
Old 02-07-2012, 10:04 AM   #19
I saw the pressure switch was kicking on at 40psi and cutting off at a little above 60. the switch has a note saying it should be 30-50. I adjusted it with the screws to kick in at 30 and stop at 50.
After taking a shower, I looked at the hot water heater and it was expelling water when that gauge by the expansion tank read 35psi.
The pictures that I provided are off all the plumbing parts between the well and the hot water tank. After the filter, its just copper t's and pipe. then the hot water tank.
Also after the water come out of the hot water tank relief valve, it seemed the pressure increased a fair amount for a second after turning on the hot water after turning on the cold on my tap.
I am not sure about anything having a check or one way valve, but I can but everything on bypass and try it.
da_man is offline   Reply With Quote
Old 02-07-2012, 08:17 PM   #20
Did a small amount of research on water softeners and it is possible that some kinds require a check valve to prevent water from going through backwards. IN that case an expansion tank is needed above the water heater.
The Following User Says Thank You to AllanJ For This Useful Post:
ben's plumbing (02-07-2012)
Old 02-09-2012, 12:33 PM   #21
I emailed the makers of the water softener and am awaiting their reply, probably will have to call them.
I was wondering if sediment in the tank could cause this problem. I was hearing boiling or some type of water movement in the tank a couple days ago. I didn't hear it yesterday, but hear ticks even after the water heater is off. Yesterday, I noticed that the relief valve ejected water like 2-3 minutes after the water heater stopped heating. It was still making the ticking noises then. Also If I use my 75gal water heater for a shower, I have to keep adjusting it to go hotter as time goes on.
Old 02-09-2012, 01:23 PM   #22
Sediment in the water heater tank won't make a difference regarding water expansion. To prolong the life of the heater this sediment should be drained out every 6 months or so, usualy it takes one or two gallons to get most of it out.
Sometimes but not always the temperature dial on the water heater may become inaccurate as the heater gets older.
Old 02-10-2012, 10:02 AM   #23
I hooked up a pressure gauge to the water tank and let the pressure build up a bit. I first turned my water filter to bypass, checked the gauge and realized that it went from 65psi to 40psi.
It seems like the GE water filter I got has some sort of one way valve. I am going to have to replace it at some point. Is this common?
I want to thank those who replied, I learned a lot about plumbing, expansion and components. I am sure if there is ever a problem in the future, I should be able to figure it out much quicker. I am just glad I don't need a new expansion tank or hot water heater yet.
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Lost Hot water pressure brile Plumbing 11 11-28-2010 03:59 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
