What Is Blowing Down Your Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-17-2015, 03:22 PM   #1
Rewards Points: 652
What is Blowing Down Your Water Heater?
I have been to the to extend the life of your hot water tank, blow it down everytime you change your air filter. What does it mean to blow it down and how do you do this? it is necessary to do it everytime your change your air filter?
kennykenny is offline   Reply With Quote
Old 07-17-2015, 07:06 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
Are you talking about the filter at the water htr base?
Old 07-17-2015, 08:07 PM   #3
Rewards Points: 582
some guys refer to doing this when you change your furnace filter...I think..but all you have to do is take alittle water maybe a gal off the bottom drain once or twice a yr....blows the dirt and junk off bottom of heater...
Old 07-17-2015, 08:10 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,032
I think he means opening the WH drain valve with the pressure on to blow out any sediment. I am on a well and have a lot of minerals in the water. I do this about twice a year into a 5 gallon bucket. I get quite a bit of crud.
Coastal South Carolina
Old 07-18-2015, 01:06 AM   #5
Plumber
Rewards Points: 348
Makes sense now. I've seen issues with the filter screens at the base of gas WH's because they don't get cleaned- that was my first thought......
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (07-18-2015)
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 11:22 PM
Water heater problems- thought I fixed the problem- what do I do next? brandall Plumbing 23 04-19-2013 06:44 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
