What Am I Dealing With Here ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2013, 10:45 PM   #46
Rewards Points: 140
Originally Posted by jagans View Post
I think I would have dont his with a Y and an 1/8 bend, and a cleanout?
yeah, i could have done it that way. but i saw no problem with doing it the way i did. and i wanted to get the job done.
i only bought 1 Y. and you can see that i had used that. so i have to get another and put it in.
what is a water test ? nothing is leaking now.
Fix'n it is offline   Reply With Quote
Old 02-24-2013, 10:47 PM   #47
Rewards Points: 140
oh.
everything is working just fine. and when i took out the old stuff, i was highly suprised at just how clean the pipes were inside.
Old 02-24-2013, 11:01 PM   #48
Master Plumber
Javiles's Avatar
Rewards Points: 984
under the old code you could not pipe in a tub down stream of a toilet new code lets you pipe it in up to 10 feet down stream of the toilet, E i think he wants everything tucked up in the joist, we can 45 the wye but need a minimum or 24 inches on the arm again thats my code that breaks the siphon action down here we actually have 2 codes we have the upc and what that doesn't cover we have the Florida plumbing code. pain in the butt
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-24-2013, 11:05 PM   #49
Master Plumber
Javiles's Avatar
Rewards Points: 984
[/PHP]
PHP Code:
what is a water test nothing is leaking now.[/QUOTE
as long as its draining nothing may be leaking but under pressure (stoppage) fittings may leak.
Old 02-24-2013, 11:07 PM   #50
Plumber
TheEplumber's Avatar
Rewards Points: 348
Makes sense. I've only worked UPC- which is overblown in some areas. Idaho is working on their own hybrid "UPC" called the Idaho Plumbing Code(IPC)- go figure...
Old 02-24-2013, 11:09 PM   #51
Rewards Points: 140
what ever gave you that idea
that space is MUCH nicer now.
Old 02-24-2013, 11:14 PM   #52
Master Plumber
Javiles's Avatar
Rewards Points: 984
OOOPs correction were under the IPC not the UPC very similar from what Ive seen
Old 02-24-2013, 11:15 PM   #53
Rewards Points: 140
[/PHP]
PHP Code:
gotcha. someone would have to drop some monsterous turds for that to happen.
Old 02-24-2013, 11:19 PM   #54
Plumber
Rewards Points: 348
Ya know Fix- It's been mentioned to put a wye at the base of the stack, but you can also use whats called a clean out tee or test tee. Might save you a couple bucks and works just as well
The Following User Says Thank You to TheEplumber For This Useful Post:
Javiles (02-24-2013)
Old 02-24-2013, 11:23 PM   #55
Master Plumber
Javiles's Avatar
Rewards Points: 984
Then it would be a good time to test the system.
Old 02-24-2013, 11:36 PM   #56
Rewards Points: 140
yes, i am, this coming weekend. i will look for this parts.
i'm not pushing my luck. though i am 99.999% sure i have it glued up well.
but ya know what. i am thinking about changing the bathroom layout (to make room for a larger vanity) and nearly all of that plumbing would be replaced anyway.
Old 02-25-2013, 04:51 PM   #57
Plumber
If they do that do you think we may have to re-test when we renew our license ?
I hate taking test.
I just renewed this month so I'm good tell Feb 2116.
DidIDoThat is offline   Reply With Quote
Old 02-25-2013, 10:57 PM   #58
Master Plumber
Javiles's Avatar
Rewards Points: 984
I hate taking test.
We dont have to worry about that in florida contractors exams has very little to do with the trade,
Old 02-25-2013, 11:43 PM   #59
Plumber
Rewards Points: 348
I hate taking test.
I doubt you'll need to retest but you will need some ID CEU by then. Best to go to the state website and read for yourself.
I picked up some Washington work from a Idaho shop cuz their jmen let their WA Jcards lapse - I live in a border town and carry both
I need to renew my WA license real soon and it takes a couple CEU classes but my ID plumbing contractors is good for a couple more years
Idaho Cont. test is a Jman exam with about 20 Idaho contractor regs thrown in.
Old 03-02-2013, 11:05 AM   #60
Rewards Points: 140
they didn't those. so i just got a wye and the fittings for it.
Dealing with split-circuit receptacles demandrew Electrical 5 12-20-2011 08:22 AM
hands all chapped from dealing with flux amakarevic Plumbing 6 09-29-2011 02:13 PM
will i need a wet saw if dealing with 1" mosaic amakarevic Flooring 17 05-20-2011 10:07 PM
What am I dealing with here? Robbinsm88 Pest Control 1 05-20-2011 03:45 PM
Dealing With old large cast iron radiators and new floors ??? ants1929 Flooring 4 02-12-2011 09:40 AM
