#31 |
Plumbing Contractor
what am i dealing with here ?
There known as "chain cutters" around these here parts although an old timer I apprenticed under called them "ratchet cutters".
#32 |
project is mostly done. i didn't think to buy 2 Y's. so i don't have a cleanout, i will put that in next weekend. putting in the floor joists, the side ones went ok, but the middle one, boy, what a task. and fitting that Y by the dented duct, that was a pita also. but i got it done at 8:30pm last night. then shower, movie and beers.
i have some cleanup to do ![]() and i have to secure the conduit up. its so nice not having the posts and pipe in the way. the clean out that i need to install. i am thinking of putting it on the wall, a little off the floor. turned to be next to the wall. is this ok ? also, if you see that i should have done something different/better, lmk. btw. the movie was pretty good = lots of action, typical. but what i thought was pretty cool was seeing the big name movie heros all in one place. those guys aren't getting any younger.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. i didn't make this world. i just live in it. be careful of whom you make fun of. one day, that could be you... |
#33 |
oh
i didn't have to pull the crapper. i was able to cut/chip the coupler off the flange without damaging it. is this normally doable, or did i just get lucky ?
#34 |
old pics here.
swiss cheez floor joist replacement
#35 |
Master Plumber
I see a couple of misplaced fittings if my eyesight has int failed me, if your under the IPC.
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#36 |
and those are ? need better pics ?
#37 |
Master Plumber
Sanitary tee on is side, and the side inlet 90
#38 |
ok, i am not a plumber, help me figure this out.
the sanitary T, is that the middle fitting by the conduit ? side inlet 90, idk what that is.
#39 |
Master Plumber
Listen your job looks good , looks a lot better than some of the jobs i run across from plumbers down here,
the tee is the one looks like its picking up a tub? and the elbow in the picture that has a 2 inch inlet, the elbows not a big deal but the tee should get changed out. if you can post a pick of that p trap area coming off that tee.
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Javiles; 02-24-2013 at 11:48 AM. |
#40 | |
what am i dealing with here ?Quote:
the tub has a T , 3" with a 1 1/2 for the tub. the crapper has an elbow, with a 1 1/2 coming off it, for the sink. this is basicly what was there before that i took out. the T, is that because i have it on the side ? pics shortly.
#41 |
here ya go.
also. cutting the steel pipe was way easy. started with an angle grinder, finished with resip saw. took about 5 mins. wonderin what i should do with the cutoff.
#42 |
oh. i would like for some estimates on what this job would cost. just to get an idea.
#43 |
Roofmaster
I think I would have dont his with a Y and an 1/8 bend, and a cleanout?
" A lot of men build things, and a lot of things fall down " Last edited by jagans; 02-24-2013 at 09:01 PM. |
#44 |
Master Plumber
What youve done is also create a S tarp. you need to get rid of that tee and come back with a wye, at move it down at leat a mininum of 24 inches then place the wye on a 45 degree as jagans posted, 24 inches from trap to wye. also a clean out at the base also as jagans posted, the elbow should have been a combo but i guess you can leave it, and should be in 2 inch not 1 1/2 again depending on your code that tub must be connected no more than 10 feet downstream from the water closet on the main. i dont like those fernco couplings for the transition future problems i would go with a no hub coupling and a no hub adapter then bushing down to 3 inch. i would also do a water test on the tub and new lines.
#45 | |
call me E
And why have the tub 10ft downstream? Again, I'm just curious
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
| Display Modes | |
| Dealing with split-circuit receptacles | demandrew | Electrical | 5 | 12-20-2011 08:22 AM |
| hands all chapped from dealing with flux | amakarevic | Plumbing | 6 | 09-29-2011 02:13 PM |
| will i need a wet saw if dealing with 1" mosaic | amakarevic | Flooring | 17 | 05-20-2011 10:07 PM |
| What am I dealing with here? | Robbinsm88 | Pest Control | 1 | 05-20-2011 03:45 PM |
| Dealing With old large cast iron radiators and new floors ??? | ants1929 | Flooring | 4 | 02-12-2011 09:40 AM |
