What Am I Dealing With Here ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2013, 07:25 PM   #1
Rewards Points: 240
what am i dealing with here ?
i am relocating that piping, up next to the wall. what i am looking for info on = is what do i need to do to connect the new pvc to the metal(cast or steel ?) pipe. i believe that it is somehow soldered together. and i need to get it apart.
on a side question. is buried pvc code ?
Fix'n it is offline   Reply With Quote
Old 02-10-2013, 07:37 PM   #2
MarginallyQualified
Rewards Points: 2,464
An adaptor. The requirements will vary by area.
There are many ways to do that.
Some easier than others and some a bloody mess.
When done correctly.
Do you have a permit now?
Do you plan to have the work inspected?
Old 02-10-2013, 07:38 PM   #3
Rewards Points: 636
you are relocating what is there to be against wall is what i understand. if so can you see the 90 on the old cast iron where it turns to go horizontal
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-10-2013, 07:42 PM   #4
Rewards Points: 14,300
Going to have to cut out more concrete intil you back to a straight pipe to connect a hubless connector to and redo that old cast clean out with PVC..
Old 02-10-2013, 07:45 PM   #5
747
registered
747's Avatar
Rewards Points: 534
Exactly your going to take out more concrete. Get to where the pipe goes straight underground. Once you get there. Everything can be replaced with pvc including red pipe. Easiest way to cut would be with the wrap around chain tool . I can't think what this tool is called. You can connect pvc with a boot and clamps to old pipe underground.
747 is offline   Reply With Quote
Old 02-10-2013, 07:48 PM   #6
Chair cutter, HD rents them.
http://www.bing.com/images/search?q=...pipe&FORM=IGRE
Old 02-10-2013, 08:09 PM   #7
Rewards Points: 240
ok. see the clean out Y, that has to go. the clean out is connected to the main pipe at a 45deg angle. the main pipe goes horizontal under the floor.
iirc, someone said the the pipes are "leaded" together, correct ? if so, could i heat with a oxy/ac torch to loosen/remove it ?
no, i am not getting a permit for this. one reason is that, after digging that hole, i found that i probably(could be thicker under other parts of the floor) don't have as thick a slab as i thought. so it would be somewhat easy to bust it all out. then have a new floor poured. after replacing all of the under slab plumbing. this would give me a 7' ceiling, 6'4" now. i am going to get estimates for having the slab poured.
Old 02-10-2013, 08:57 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 904
You'll need to expose the 45 at the stack base. There, you'll find its joined to the main with a lead&oakum joint. I usually try to drill the lead out with a small drill bit or snap the pipe as mentioned earlier. By saving the hub you can use a rubber "doughnut" like the one you already have in the vertical stack.
Once you extend the pvc to the wall- use a long sweep 90 or two 45's to turn vertical- you also need a clean out there.
Old 02-10-2013, 09:11 PM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 996
SOIL PIPE CUTTER SOIL PIPE CUTTERS SOIL PIPE CUTTERS
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-10-2013, 09:16 PM   #10
Plumber
Rewards Points: 904
Silly plumber- they're SNAP CUTTERS!!
Old 02-10-2013, 09:34 PM   #11
Rewards Points: 240
it already is, just can't tell in the pic because of the dirt.
drilling, is this a reasonable way to do it ? i mean = does it take forever ?
i don't want to "snap" it. i am afraid that that may break a perhaps already fragile pipe.
thanx for the tips
Old 02-10-2013, 09:44 PM   #12
MarginallyQualified
i mean = does it take forever ?i don't want to "snap" it.
After you cut out 8 or 10 sq feet of concrete and remove the dirt around the pipe so where you'll be making the cut is easy to get to...
and you have a hub/adaptor in your hand to put it all together again with...
then decide how finicky you want to be with the cutting.
Old 02-10-2013, 10:41 PM   #13
Master Plumber
Javiles's Avatar
Rewards Points: 996
Google soil pipe cutter and see what happens Google snap cutters same thing comes up Ok so we are both right.
Old 02-10-2013, 11:12 PM   #14
747
registered
747's Avatar
Rewards Points: 534
Yes this is what i meant. To the original poster she will snap clean. In a matter of minutes,
Old 02-11-2013, 05:08 PM   #15
Rewards Points: 582
don't bet on that...cast iron cutter.... ben sr
Dealing with split-circuit receptacles demandrew Electrical 5 12-20-2011 07:22 AM
hands all chapped from dealing with flux amakarevic Plumbing 6 09-29-2011 01:13 PM
will i need a wet saw if dealing with 1" mosaic amakarevic Flooring 17 05-20-2011 09:07 PM
What am I dealing with here? Robbinsm88 Pest Control 1 05-20-2011 02:45 PM
Dealing With old large cast iron radiators and new floors ??? ants1929 Flooring 4 02-12-2011 08:40 AM
