That is a piercing valve. Most plumbers hate them. They end up leaking as time goes by
It either fed your refer or a make up water line to a piece of HVAC equip. in your basement.
If you unscrew the tee handle water will come out the hose. I suggest, when you get around to it, turn off the house supply, remove the valve, cut the pipe at the small hole and rejoin it using a "shark bite" coupling.
By the way, fixing that is practically an advertisement for SharkBite. That and PEX are the best things to ever happen for DIY plumbers. No fire, no molten metal, easily undone if needed, and you can always work on wet pipe.
It's a needle tap for an icemaker most likely. Yes, don't try to remove it. It will leak. Don't turn that little handle to the left, it will open and "leak".
Instead of putting a piece of pipe or a shark bite in, can I put a drop of solder on the pin hole instead?[/QUOTE]
IMO, that would be like putting a piece of bubble gum in a hole in a dam. It just wouldn't hold the pressure. E's got the best advice if you want to fix it down the road sometime. Sharkbites are quick, easy and require no soldering and are just as good as soldering.
If it's not leaking, don't mess with it until you are ready to fix it properly.:thumbsup:
don't solder it- it won't hold. Plus if you have any water in the pipe, the solder won't get hot enough. That's why I suggested a shark bite. It' easy to use in wet conditions
I'm hoping the white wire with the bare end was used as a pointing device by you when you took the picture and not a bare wire hanging around.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
