Old 02-03-2012, 12:28 AM   #16
retired elect/hvac/plumb
plummen's Avatar
what 1 handle tub faucet
Mopar stuff is scarce and pricey around these parts,although i must admit im a sucker for 60s-early 70s mopars as well!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-04-2012, 07:40 PM   #17
Originally Posted by jaydevries View Post
be careful buying at box stores for plumbing valve most have cheaper internal parts and more expensive to replace parts.
i personally like the delta multi choice valve with the 1700 series it is able to control volume and temp separate but in a stack hard to explain look at link
http://www.deltafaucet.com/search/re...ml?q=17+series
and if you do ever get a drip it is easy to fix with a quad ring kit and free just call delta
THIS. To the OP: you do not WANT a one handle faucet. I have one, and if I can't plumb it out to what jay is showing in his hyperlink, I'll hire someone to do it! The one handle solution is awful, trying to reduce or increase pressure invariably leads to an (unintentional) temperature change (sometimes a large temperature change).
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 02-04-2012, 08:25 PM   #18
plummen's Avatar
Whats wrong with a good single handle faucet?
In some areas you arent allowed to install anything but a single handle anti scald faucet any more
The Following User Says Thank You to plummen For This Useful Post:
oh'mike (02-05-2012)
Old 02-04-2012, 08:28 PM   #19
I thought that was code everywhere ...having anti scald faucets....single control ..?????did I miss something//
Old 02-04-2012, 08:31 PM   #20
plummen's Avatar
I never get to do much plumbing in california or chicago land....,so I figured it was safer to say certain places rather than face the wrath from those above!
DangerMouse (02-05-2012)
Old 02-04-2012, 08:48 PM   #21
ok thats youIAM NOT AFRAID OF NO POST
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (02-04-2012)
Old 02-05-2012, 12:05 AM   #22
Although an anti-scald valve is a very good idea its always better to turn down the hot water temps at the hot water heater.
jasin is offline   Reply With Quote
Old 02-05-2012, 12:48 AM   #23
Super Moderator
Anti scald valves are code here----good idea,too----( But I'm in Chicago land where the codes are written from the governors wing at the federal penitentiary)
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
DangerMouse (02-05-2012), plummen (02-05-2012)
Old 02-05-2012, 03:00 AM   #24
I would never use an Anti-scald valve in place of turning down the water temp or visa versa.
Old 02-05-2012, 07:54 AM   #25
Super Moderator
Thank you for that informative post. Precisely what temperature would you recommend and what do you do about permits and inspections,is there a variance that you apply for?
Old 02-05-2012, 11:51 AM   #26
For children & adults it should be no more than 110°F - 115°F.
http://www.energyguide.com/library/E...ubjectID=10182
http://www.cpsc.gov/cpscpub/pubs/5098.html
Old 02-05-2012, 12:03 PM   #27
call me E
TheEplumber's Avatar
I don't trust anything the gov. prints
I set it at 120. No more, no less.
Old 02-05-2012, 12:03 PM   #28
Super Moderator
Please tell us how you get around code in the united states and Canada?
Old 02-05-2012, 12:23 PM   #29
Doing it myself
Alan's Avatar
"The water heater thermostat shall not be considered control for meeting this provision"
Journeyman Plumber
Old 02-05-2012, 12:25 PM   #30
Doing it myself
Alan's Avatar
OMG, you are going to give people legionnaires disease! ! !
I don't adjust them at all. Factory setting. If H.O. wants to play with their thermostats, that's on them.
Journeyman Plumber
Replacing 2 handle faucet with single handle faucet vcheez Plumbing 6 10-19-2011 11:26 AM
Broken Shower Faucet Handle DFT Plumbing 1 02-23-2011 09:55 AM
Two handle kitchen Faucet invisible screw: Leaking Faucet chicago7100 Plumbing 8 09-20-2010 09:24 AM
single handle or double handle faucet for bathroom aundav Remodeling 5 06-16-2010 05:56 PM
deciphering faucet handle EdPDX Plumbing 1 11-05-2008 08:12 AM
