Wet Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2012, 09:01 AM   #1
Wet Wall
I had a big plumbing issue that was repaired a while ago. There was a crack in the pipes in the crawl space under the bathroom. We had to tear up the floor and wall. We got the floor done and now am about to start working on the wall.
I wanted to just paint the wet wall but I was told by my dad that I can't just paint it, I have to do paneling or tile on the wet wall. Is that correct? Are there other options?
BeeTee is offline   Reply With Quote
Old 01-27-2012, 10:40 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Dry the wall off then you can do anything to it.
Seriously, do you mean the plumbing wall? You can paint it if you want to. Why not?
titanoman is offline   Reply With Quote
Old 01-27-2012, 10:48 AM   #3
By wet wall I mean the plumbing wall where the shower, toilet and sink are installed. There's already tile in the shower, so the wall area I mean is behind the sink and toilet.
Old 01-27-2012, 11:03 PM   #4
It's fine to have drywall where water pipes run inside.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
plummen (01-28-2012)
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 06:17 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
