Wet Venting - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2013, 09:04 AM   #1
Wet venting
I know you can wet vent fixtures that are on the same floor but lets say I added a shower in the basement wouldn't I have to extend the vent pipe up and over the first floor fixtures and tie into the stack to avoid the wet venting?
miguel24932 is offline   Reply With Quote
Old 03-24-2013, 09:16 AM   #2
Rewards Points: 616
ipc code
http://publicecodes.cyberregs.com/ic...?bu2=undefined
it need to be tied into a dry vent stack 6 inches higher than flood rim of fixtures on the next floor
or use an a.a.v. (cheater vent)
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-24-2013, 11:51 AM   #3
Originally Posted by jaydevries View Post
ipc code
the link you sent me basically says wet venting only allowed for fixtures on the same floor, correct? Other than that the vent needs to extend up and over the fixtures of the next floor?
Old 03-24-2013, 12:03 PM   #4
Rewards Points: 616
here is the only exception
Old 03-24-2013, 04:29 PM   #5
I read the article on circuit vents but am still confused. What exactly is that? Does that mean the drains for the fixtures run horizontally and eventually drain into the vertical main waste stack? And a separate vent stack is used for these fixtures?
Old 03-24-2013, 05:54 PM   #6
Rewards Points: 1,700
A common vent is still on the same floor.
Old 03-24-2013, 06:21 PM   #7
A common vent is just a vent stack that is shared by more than one fixture, right?
Old 03-24-2013, 06:31 PM   #8
I suggest you read the definitions of the terms you are using. It might help you understand what your trying to do.
STACK. A general term for any vertical line of soil, waste, vent or inside conductor piping that extends through at least one story with or without offsets.
STACK VENT. The extension of a soil or waste stack above the highest horizontal drain connected to the stack.
FIXTURE DRAIN. The drain from the trap of a fixture to a junction with any other drain pipe.
COMMON VENT. A vent connecting at the junction of two fixture drains or to a fixture branch and serving as a vent for both fixtures
http://codes.ohio.gov/oac/4101%3A3-2
The Following 3 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (03-24-2013), mj12 (03-24-2013), TheEplumber (03-24-2013)
Old 03-24-2013, 06:35 PM   #9
The shower would be individual vented. Your tie in must be a min of 42 inches above the first floor floor. You can tie into the vent stack at that point.
A vent stack is when that 3 inch pipe is no longer acting as a drain for anything and is just going out the roof and providing air.
Old 03-24-2013, 07:40 PM   #10
How are you getting 42 inches? It says 6" above the highest fixtures flood level.
Old 03-24-2013, 07:40 PM   #11
Old 03-24-2013, 08:06 PM   #12
Plumber
TheEplumber's Avatar
Rewards Points: 350
42" is a rule of thumb- kitchen sink flood rim = 36" + 6" = 42"
Old 03-24-2013, 08:39 PM   #13
What do you mean kitchen sink is at 36". That part I don't understand.
Old 03-24-2013, 09:40 PM   #14
Lord of Slums
Rewards Points: 1,974
36 inches is the point they are saying your vent would no longer flood. Maybe they could of said 30 inches, maybe 24 inches. 36 inches is what they are agreeing on. Then just add 6 inches. Why did they come up with this number? I would hope from experience and common sense. I would hope a bunch of plumbers made all the drain pipes of a house in clear plastic. Then sat around for weeks watching what happened as water went down the drain
mj12 is offline   Reply With Quote
Old 03-24-2013, 09:44 PM   #15
Lord of Slums
Ghostmaker, showers have to be individually vented? Does that mean a two inch vent all the way through the roof? Nothing else connected to that vent?
Ridge Cap Venting Issues - Poor Ventilation?? askeyb Roofing/Siding 16 03-29-2016 05:05 PM
Venting and insulating 1 1/2 story helgymatt Roofing/Siding 1 02-22-2011 07:58 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 02:21 PM
Gas furnace venting Qs (non high eff) WallyWoggle HVAC 6 12-09-2010 07:41 PM
Soffit venting vs. DCI Smart Vent JDPII Roofing/Siding 1 02-28-2009 09:42 PM
