Old 02-06-2011, 03:42 PM   #1
Wet vent question
I will be using about 4 feet of a 2 inch pipe for wet venting a toilet. 2' horizontal and 2 feet vertical. In a typical vent installation, the vent comes off of the top of the drain pipe. In a wet vent situation, the drain is used. So I am wondering about the angles that the 2" pipe will need to enter the 3 inch pipe as a wet vent. Is it just a standard horizontal slope of 1/4 inch per foot?
It shouldn't enter on the top...right?
wease is offline   Reply With Quote
Old 02-06-2011, 08:08 PM   #2
Wet vent question
in my code, you can only wet vent in the vertical, its a big no no horizontally. you might check that you're allowed to do it before you do
the_man is offline   Reply With Quote
Old 02-06-2011, 10:58 PM   #3
Wet vent question
The code discusses wet venting horizontally. Just difficult to understand the terminology. I believe I can go up to 6 feet with a pipe size one over the required for drainage of the upstream fixture. In my case that would be 2".
Vent slope question dj_backq Plumbing 0 10-13-2010 08:01 AM
Water Heater Vent Question pd417 Plumbing 1 05-15-2010 01:34 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
New furnace combustible air vent question simonb HVAC 12 06-12-2009 08:04 PM
Return air vent question sidewayzisbest HVAC 5 05-10-2009 04:39 PM
