Wet Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2013, 06:32 PM   #1
analogmusicman's Avatar
Rewards Points: 560
wet valve
I have a water valve which is wet all the time. it appears to be the "stem" which is wet. (it doesn't look like anything is actually leaking) can the stem be "re-packed"? (I've heard you can do that) how do I do this and what do I need? the valve is rather inaccessible so if it's an involved procedure,I may have to go through a wall in an adjacent closet.
tnx,
analogmusicman is offline   Reply With Quote
Old 07-07-2013, 06:41 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 682
If it has a packing nut- then try to snug it up a 1/4 turn or so with a wrench.
The nut is on top of the valve with the stem coming out of it.
The next option is to repack it. Different products are used for this and your home center will have.
Before removing the nut, be sure it is not under pressure as the nut also holds the guts inside the valve.
There are also valves that are not repack-able so replacement may be the only option
There is a slim possibility you are only dealing with condensation on the outside of the valve
The Following User Says Thank You to TheEplumber For This Useful Post:
jmon (07-07-2013)
Shut off valve for outdoor spigot C4per Plumbing 15 11-24-2012 07:50 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 03:04 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
