Wet Patio - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2012, 12:34 AM   #1
wet patio
I have just purchased a house and the pavers at the back of house are always wet in the morning. I lifted a few up and found sandy soil and lots and lots of water. It takes most of day to dry pavers but I need to know how to fix the problem and first of all know what is the problem.
Thanks for any help
dianapinon is offline   Reply With Quote
Old 01-03-2012, 08:35 AM   #2
Lightfoot's Avatar
Rewards Points: 272
boy, that's not much info to start on.
downspout nearby?
shut off all water in house and do a water meter check?
have you had lots of rain recently?
if not, where could the water possibly be coming from?
we don't know where to start.
Lightfoot is offline   Reply With Quote
Old 01-03-2012, 08:56 AM   #3
Rewards Points: 1,442
After a few nice and dry days, dig a hole a few feet away from the patio and perhaps a foot deep. If the hole fills with water you can have a high water table problem. If the patio is just wet you may decide to live with it but if there is a layer or puddle on the patio you may need to put in a drainage system.
AllanJ is online now   Reply With Quote
Old 01-04-2012, 07:14 AM   #4
Lightfoot's Avatar
Rewards Points: 272
i'm thinking we may have stumbled upon a classic case of Oh'Mike's "google poster".
The Following User Says Thank You to Lightfoot For This Useful Post:
dianapinon (01-04-2012)
Old 01-04-2012, 09:47 AM   #5
MarginallyQualified
Rewards Points: 2,464
Originally Posted by dianapinon View Post
I have just purchased a house and the pavers at the back of house...
Wanna guess what the ratio of total paver jobs done...
is to properly done paver jobs?
Then you still have the water condition factors as well.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Old 01-04-2012, 12:16 PM   #6
Rewards Points: 1,294
Well, since the original poster is most likely a "one hit wonder" I guess a little tread drift is OK. I would guess the number is something like 10:1. This is based off of what I found under my front walkway this past summer. 5 inches of sand over a clay/topsoil mix. Had to tear it all out due to it moving up and down all over the place. Dug down an additional 6" to get to the nice gravel layer I am fortunate enough to have under my whole property and rebuilt from there.
For the OP, if you are still here. The sandy soil you found under the pavers is the bedding sand that pavers are properly placed on
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Old 01-04-2012, 01:14 PM   #7
concretemasonry's Avatar
Rewards Points: 2,578
The setting bed of sand should be a maximum of about 1" thick and placed over a compacted "gravel" base. Excessive setting bed thicknesses are bad and lead to the pavers rocking, floating and not really interlocked the way they should be. - It is just a case of not installing a proven product they way it should be done.
Dick
concretemasonry is online now   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Pouring Patio Slab and Post Footings Question average_male Building & Construction 22 04-04-2016 01:13 PM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 10:53 AM
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 03:35 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
