Old 03-02-2007, 09:04 AM   #1
Wet bar project
I am in the process of putting a wet bar together in our basement, actually more of a kitchen minus a stove/oven.
I intend on having a single basin sink. I have existing water lines in the ceiling directly above where the sink will be placed. I'm pretty confident in running the necessary hot and cold lines.
My question pertains to the drain. I have a vertical drain stack that is running into the concrete floor approximately 30" from the new sink. Can I simply run a PVC pipe to this drain and tie into it? Assuming I provide some type of pitch.
Bigman610 is offline   Reply With Quote
Old 03-02-2007, 09:08 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Wet bar project
According to my code book, if that vertical drain is the maindrain then yes. It will also serve as the vent.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-02-2007, 09:11 AM   #3
Wet bar project
Thank you very much Ron. I appreciate the help. Please don't take it for granted, I'm sure you have helped more people than you realize. Speaking for myself you have been help, simply by reading several of your posts. Thanks again.
Old 03-02-2007, 09:12 AM   #4
Journeyman Plumber
Wet bar project
I try my best.
My Custom In-Wall Entertainment Center Project! With lots of photos!! joseph011 Project Showcase 12 01-03-2011 02:43 PM
Family Room Project ktkelly Project Showcase 0 05-16-2007 09:48 PM
A newbie basement finishing project DIY4EVER Building & Construction 6 05-11-2007 10:48 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
