Well Water System Pressure Spikes - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-06-2012, 06:48 AM   #1
well water system pressure spikes
I am having pressure spikes. I noticed the pressure spiked to 120psi
for just a second when the air pump shut off. However, I have seen
the gauge read 200 (+) psi., the gauge has an indicator which stays
at the peak pressure. I 'm not sure when the spikes occur, but I do
know that at times the toilet makes a very loud bang/pop sound
when flushed. Also at times there is air in the water lines. Does
anyone know what may be causing these occurrences?
Idea2 is offline   Reply With Quote
Old 05-06-2012, 08:46 AM   #2
I=E/R
a7ecorsair's Avatar
What do you mean air pump?
What type of pressure tank do you have?
a7ecorsair is offline   Reply With Quote
Old 05-06-2012, 09:07 AM   #3
We have an air pump which puts air into an iron removal tank.
As for the pressure tank,it has no label I can see. How can I tell what kind it is?
Old 05-06-2012, 09:31 AM   #4
I took a 2nd. look, now I see the label on the tank reads
"wellxtrol". That's it as far as what kind. I'm new to well
water systems, but not to plumbing in general.
Old 05-06-2012, 12:16 PM   #5
I=E/R
a7ecorsair's Avatar
Your pressure tank has a bladder inside which could be broken. You will also see an air valve like on an inner tube.
Pressure tanks provide a cushion so the pump can run without turning on and off every second. The pressure switch will turn the pump on when the low point is reached. The pump will run and deliver water to open faucets and also to fill the pressure tank. The pump will run until the upper limit is reached.
30# to 50# is pretty common for today's 4" pumps.
Does your pump cycle frequently? You should be able watch the pressure gauge and tell us how it behaves.
Repairing converted Steam to Hot Water Radiator system - HELP! JonathonT HVAC 0 09-27-2011 10:08 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Lost Hot water pressure brile Plumbing 11 11-28-2010 03:59 PM
Well Water System Problem browning Electrical 6 09-12-2010 07:14 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
