Well Water Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2012, 10:16 AM   #1
well water pump
I thought my water line was frozen, but when I turned the outside faucet on, water flowed a few minutes then stopped. The pump came on, but continuously runs. The PSI is below 10. I unplugged the pump, waited, and plugged it back up. Should I prime the pump, or how do I increase thePSI?
glendagriffin is offline   Reply With Quote
Old 01-21-2012, 11:36 AM   #2
Maybe it is frozen. How deep is your pump set. The top of the water line on my well is at about 10 feet but my pump is set at 450'. I am in Georgia so freezing isn't an issue, but In MN the top would freeze I would bet, causing me issues further down
____________
Check out my Man Blog
jasonreck71 is offline   Reply With Quote
Old 01-21-2012, 11:39 AM   #3
Dumb me just realized we are thinking different water lines. The main water line into my house is buried at 4 inches...I suspect you could have some ice build up somewhere in the system...Again depends where you live, if it's in Tewas then I suspect not
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
pool pump fill then dumps water nanderson360 Plumbing 2 10-14-2010 10:58 AM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 08:01 AM
