Well Water ? - No Water At Yard Hydrants... But Do Have Water In House - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2010, 12:37 PM   #16
Water quality'n pump guy
Unless you have frost free hydrants installed properly with sufficient drainage under them, my assumption (assumptions against any possibility should not be made) is that you have two (or 3) separately frozen hydrants.
You can have had a serious leak for months and not be able to see any evidence of it on the ground.
And PEX was a poor choice, 3/4" or 1" 160 or 200 psi rated PE pipe would have been much better. And if you really mean that the hydrants are black iron pipe instead og galvanized, they could be rusted shut. PEX is copper tubing size (CTS), the OD is maintained, and PE is iron pipe size (IPS), the ID is maintained (so you get more water).
So run a new PE line fed by a garden hose from the house on the ground to water the horses and install threaded sch 40 PVC unions to easily drain it after using it.
Gary Slusser
23 years in water treatment and well pumps, 13 years on the 'net helping others to help themselves.
Gary Slusser is offline   Reply With Quote
Old 01-05-2010, 01:15 PM   #17
Rewards Points: 150
To the OP. Does your hydrant have something that looks like a plastic straw running down the side?? If so, although those are frost free, they have to be blown out with a compressor.
They make us do that to code now. (DEQ)
user69544 is offline   Reply With Quote
Old 01-05-2010, 01:19 PM   #18
Rewards Points: 150
Size:  20.9 KB It is taped on the wrong side to see on the hydrant but, maybe you can see enough.
Old 01-05-2010, 01:59 PM   #19
Originally Posted by Bondo View Post
And how Deep was it buried,..??
I buried it to my chest, 4+ feet down.
mntnvew is offline   Reply With Quote
Old 01-05-2010, 02:09 PM   #20
I really TRIED to educate myself before I installed them and I put a crap load of 2-3 inch gravel, then 1-2 inch gravel, then 6-8 inches of sand underneath the hydrants and I got the 9 foot hydrants and only 2.5 feet is above ground, so they are WAY DOWN there.
By serious leak do you mean a outright POURING of water @ 23 gallon a minute? That is what our pump puts out at the yard hydrants, tested last fall. Right now I open them and NOTHING happens, not a drip, sound, nothing.
No I was referring to the actual well piping, not the yard hydrants, 2 of the three were new 2 years ago. the older one is old but works fine, until 2 nights ago.
That works for non-sub zero days, but when we are subzero, the water hose freezes before the water can get out the other end to create a flow. It is 300-350 yards.
I am just baffled, the damn thing was working GREAT on a daily basis and then all of a sudden... It isnt even that cold!!!!
Old 01-05-2010, 02:10 PM   #21
Rewards Points: 150
4 foot isn't much if you drive over it. If we have to go though a person's driveway we lay foam insulation over the line, then we fill it in. In the summer you could try that.
Old 01-05-2010, 02:24 PM   #22
REALLY? I dont mean to act like I know up from down, but dayum!!!
When I was trenching the line I could see where the frost line had been and it was at 28 inches down. We live in HIGH DESERT, so the soil is sand with large rocks, the rockies Dont get me started on driving fence posts, UGH!
And the line has been through 2 winters without issue, working on a daily basis to provide water to barn & horses via yard hydrants.
I guess I was hoping someone would say, man if 23 gallons a minute was flowing out under ground you'd have a sink hole after 2, three now, days of nonstop running, or my well pump would have broke by now.
I dont know where to start, I do NOT want to dig up my yard, $ is tight in these times and new materials to run a new run would be more then I could afford right now.
UGH!!!!!
PS - Any well pump experts on here? Are my previously assumptions accurate? Would I hear the heavy duty pump on all the time if I had a leak of 23/gallon a minute rushing into the ground?
What about the pressure when I open a yard hydrant, shouldn't I get SOMETHING out of it even with a leak/break in the line?
I guess I should run a damn garden hose to it from the house and see if I can get it to come out the other end....
This is frustrating to say the least.
THANKS ALL!
Old 01-05-2010, 02:31 PM   #23
The loss of pressure like that would lead me to believe the well pump, or is that wrong of me to assume the pump?
Same pump for the house right? If you have pressure in the house then it isn't the pump.
My relatives in Pennsylvania have a 48" frost line. I have to believe it's deeper in Montana. When I do a casual google search I'm seeing 5 feet and 6 feet (probably depends on the part of the state).
pyper is offline   Reply With Quote
Old 01-05-2010, 02:39 PM   #24
Rewards Points: 150
UGH!!!!!
THANKS ALL!
Listen and see if your pump is running when no water is being drawn. If you drove over the frost line it is deeper.
Old 01-05-2010, 02:41 PM   #25
Rewards Points: 150
Mine would pump the same in the house with a broken line outside but, I would have a lake by now.
Old 01-05-2010, 03:11 PM   #26
the Musigician
DangerMouse's Avatar
Furthermore, the last time I did use the yard hydrant in my barn, which is the farthest away from the well, the water pressure all of a sudden took a dump and was at about 50% flow.
I'd be wondering about this..... crud in the line maybe? not freeze?
recent pex work....? is the pump cycling? listen for a while....
DM
Old 01-05-2010, 03:32 PM   #27
DM
Could be crude I guess... but it was working fine 3 nights ago now. No recent work on anything.
Pump is cycling in the house, it turns on and off as usual
Old 01-05-2010, 03:38 PM   #28
Licensed Master Plumber
chance of all three hydrants being frozen is pretty slim. Chance of the pipe that feeds the hydrants being frozen is more likely.
NHMaster is offline   Reply With Quote
Old 01-05-2010, 03:50 PM   #29
Rewards Points: 150
Yep, it is T-ed off someplace. That is were I would start.
Old 01-06-2010, 02:00 AM   #30
IIRC he said 1 of the 3 is working and the 2 that are not are on separate lines teed off the main line. You could look that up and let me know if I'm wrong.
Gary Slusser
Tags
no water at spigot , spigot , well pump , yard hydrant
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Old house with water troubles wade Plumbing 1 01-16-2008 08:24 AM
