Well Water Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2012, 11:26 AM   #1
Well water lines
We have no pressure coming into the house. the well is working and we have pressure under the houes. No when we drain the line, we have hot water coming back out instead of cold but no hot or cold water in the house spickets
freyja923 is offline   Reply With Quote
Old 02-08-2012, 11:27 AM   #2
I am getting an error when I try to open the chat. Will try a new computer and see if I can see the response
Old 02-08-2012, 11:34 AM   #3
HELP!! Is there a way to tell if there is a blockage in the house pipes without tearing apart the walls etc. ?
Old 02-08-2012, 02:05 PM   #4
Rewards Points: 104
The first thing that comes to mind is a frozen pipe; where are you located, and is this a possible scenario? What do you mean by "the well is working"? Is the pump running? If the pump is running, and the water is not coming into the house, I would suspect a ruptured line. What do you mean by "we have pressure under the house"? I suspect that the hot water at the spiggot(s) is the result of siphoning back out of the water heater, due to the loss of pressure in the system.
Old 02-08-2012, 03:35 PM   #5
The pump current draw may give you another clue.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
replacing hot/cold water lines ontop of hot water heater tank rickwest59 Plumbing 10 10-11-2011 08:09 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
correct size pipe for water lines jce Plumbing 2 04-11-2010 08:23 PM
