Old 07-12-2010, 06:13 PM   #1
Well Water has Air Bubbles
My wife and I recently purchased our first house. The house is currently hooked up to City water, but after going in the crawl space we noticed that the house also came with a well. The well had been disconnected so we decided to hook it back up to use for irrigation. After making sure everything was connected we attached a garden hose to it and ran the water. From there we noticed a couple of things, the first being air bubbles in the water flow. Second is fluctuation in the flow of water. Can anyone suggest anything to resolve this issue.
hub151 is offline   Reply With Quote
Old 07-19-2010, 10:31 PM   #2
Is it a submersible or jet pump ? Is there a pressure tank ? Pressure switch ? More info.
rudolph58 is offline   Reply With Quote
Old 07-20-2010, 10:20 PM   #3
You should pull a water sample and have it tested too just to be safe - even if it's only for irrigation. No telling what could happen in the years the well wasn't in use.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 07-21-2010, 07:39 AM   #4
Thanks for the replies. It is a Jet well and has an expansion tank and pressure switch. It took about 3 minutes to fill up a 10 bucket.
Old 07-21-2010, 07:57 AM   #5
Long-Time DIYer
Mike Swearingen's Avatar
The air bubbles may possibly be from a leaking bladder in the pressure tank, or there could be a fitting leak on the suction (well) side of the pump sucking in air. Most likely it's a bad tank bladder.
Turn the pump off or unplug it, and drain the water pressure down until it stops running out.
Now, check the pressure in the tank with a tire pressure gauge. It should read (and hold) two psi below the pump cut-on pressure (i.e. 20 psi cut-on to 40 psi cut-off should have a tank pressure of 18 psi when the pump isn't on and the water pressure is drained down).
If the pump is set at 40 psi cut-on/60 cut-off, the tank pressure should be 38 psi. If the tank pressure is too high, bleed the air pressure off to the 2 psi below. If it is too low, air the tank back up with a portable compressor or air tank.
If water spews out of the pressure tank air valve, the bladder is shot and you need to replace the pressure tank, which is what I suspect will solve your problem.
If you need to know how to prime the pump later, just ask.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-21-2010, 11:08 PM   #6
Does the pump turn on and off rapidly when using water.With the tank unhooked from the system,is there still water in the tank ?
Old 07-21-2010, 11:09 PM   #7
PS:How deep is the well ?
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
No Hot Water comeing out of Faucets gangstacro Plumbing 5 11-30-2008 04:32 PM
