Well Water Fluctuation - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-21-2012, 08:43 AM   #1
well water fluctuation
The water in the house fluctuates constantly and the temperature of the water changes with that fluctuation.
lablake5 is offline   Reply With Quote
Old 06-21-2012, 09:03 AM   #2
joed's Avatar
Rewards Points: 12,918
It is normal for a well system water pressure to fluctuate. The pump will typically go on at 30psi and off at 50 psi. that means the water pressure will drop to 30 before the pump comes on.
I don't know about the heat issue. Is any of your suction pipe exposed to the sun. It could be solar heating.
Give us more details about your system.
Old 06-22-2012, 03:21 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Water will come out of the ground at 52-55 degrees and be pretty constant. It may heat up in the pressure tank to match the temperature of the surrounding space if it sets there for a time.
Old 06-22-2012, 04:11 PM   #4
DIY staff
Rewards Points: 7,174
Describe your system---Water pressure should be constant if you have a working pressure tank--
Tell us what you see----
Old 06-22-2012, 05:19 PM   #5
Rewards Points: 13,748
I think Mike's dead on with this one.
If the bladders bad in a pressure tank there's no storage area for the water to be stored and the pump just turns on and off.
oh'mike (06-22-2012)
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
