Well Water With Air In Lines...? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-13-2012, 06:33 PM   #1
Well water with air in lines...?
Just bought a new house and it runs off of well water I have a few questions. When you turn the hot water on the water is more rusty(this happened before I put the water heater in and after they had the lines run together it was elbowed together at the hot water heater) and when I turn the hot water on it keeps shooting air through the lines. (this also happened before and after the installation of the water heater).. Any ideas on what it could be? Thank y'all
dane61 is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
replacing hot/cold water lines ontop of hot water heater tank rickwest59 Plumbing 10 10-11-2011 08:09 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
correct size pipe for water lines jce Plumbing 2 04-11-2010 08:23 PM
