Well Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-30-2013, 11:12 AM   #1
Rookie Homesteader
Well Water
I recently purchased a couple of acres that came with a well drawing from the aquafir. The water has a sulfur smell to it. I'm getting all sorts of people convinced they can help me get rid of the smell starting at $1,000.
Any well water users out there able to assist?
hoganj is offline   Reply With Quote
Old 10-30-2013, 11:24 AM   #2
Rewards Points: 12,856
This should explain it.
http://www.mrwa.com/watersmellrotteneggs.htm
Old 10-30-2013, 11:48 AM   #3
Master Plumber
Benplumbing's Avatar
Helen brand makes a very good filtration system that will take out all smells taste and iron.. You're probably looking at a couple grand installed. That would probably be on the high side. But they are one of the best out there!
Benplumbing is offline   Reply With Quote
Old 10-30-2013, 10:56 PM   #4
Rewards Points: 172
I just purchased my first home with a well also. I was told that if the water hasn't run for a while it could get that smell, and all you need to do is run it for a while. It took a day or 2, but the smell is gone.
nateshirk is offline   Reply With Quote
Old 10-31-2013, 10:08 AM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
When we lived in Texas we had a similar problem. We installed a system which aerated the water into a holding cistern. This got rid of the smell.
Then we added filters to clean it up.
Old 10-31-2013, 07:28 PM   #6
Civil Engineer
Rewards Points: 4,520
Water problems like yours can have a variety of causes. A good place to start is to get your well water tested by a laboratory for standard problems like high sulfur content, iron, manganese, chlorides, and a few other common items. Most labs have a standard well test series, and should be able to suggest what you need to test for that may be beyond the standard series. It is not generally fruitful to discuss options for correcting a well water problem until you have thoroughly defined the problem, and that has to start by getting the water tested.
Daniel Holzman is online now   Reply With Quote
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
