Well To Tank Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2012, 09:16 PM   #1
In the basement I have a tank for the well system. The 3way brass fitting in front of tank uses copper to connect to tank and copper connect to the house water line. The connection to the flex black line coming from the pump (through foundation) uses a short PVC between pump line before screwing onto the brass fitting.
A recent repair job now has the PVC to brass fitting dripping very slightly. Should I just replace the small PVC with copper between brass fitting and the plastic flex line from the well.
ken57 is offline   Reply With Quote
Old 01-17-2012, 09:21 PM   #2
Rewards Points: 582
not sure what your saying a picture would help...but if you think its an easy fix sure do it ...ben
Old 01-17-2012, 10:45 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 352
I think you're describing the pressure switch? At ant rate, replace the PVC with PEX, copper or more poly (flex black line) if it's a short run
Old 01-18-2012, 02:08 PM   #4
Thanks. That is exactly what i did. Remove the 18" inches between the poly and the fitting and went 100% copper.
Old 01-18-2012, 07:53 PM   #5
Rewards Points: 582
great job knew you could do it ben
Hot Water Tank Flammable Vapor Sensor Lockout - A.O. Smith - Promax taviyo Plumbing 11 08-14-2013 05:51 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Leaky Toilet Tank Valve Tuckahoe Sparkplug Plumbing 4 07-10-2010 07:21 AM
Flooded Salt Tank in Kenmore H2O Softener whitedavidp Plumbing 2 01-07-2010 01:05 PM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 12:09 PM
