Old 01-14-2013, 11:55 AM   #16
Roofmaster
well question
His pipe is probably plastic, and stainless is about as good as you can get.
" A lot of men build things, and a lot of things fall down "
Old 01-14-2013, 12:38 PM   #17
well question
yes the water line is 1" plastic. the one i took off was brass- i will look for a stainless 1 if thats better.
i had an acid nuetralizer put in a year ago and contemplating a softner-harness is right on the line of needing one now that a nutralizer is installed.....
i did the hand over hand pull while the helper walked the end of the line away
you are right below me- small world
gwilkrrs is offline   Reply With Quote
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
