Well Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2013, 01:35 PM   #1
Rewards Points: 91
well question
so i can hear water running in the pipe as it comes into the house from the well- the pump isnt constantly running since i hear it click on and off but i do hear moving water when there isnt a demand for it. i hear it moving from where it enters the house thru the blue preasure tank and thru the pipes into the acid nuetralizer but nothing out of the nuetralizer. the gauge is reading 62lbs. i thought maybe a line was leaking either in the well or thru the yard but wouldnt that have the pump running non stop? just confused.....
gwilkrrs is offline   Reply With Quote
Old 01-12-2013, 03:33 PM   #2
Roofmaster
Rewards Points: 2,210
62 lbs is pretty high. Mine is at 40. No, a leak may not keep up with the pump, the pump buils up pressure, the leak reduces the pressure, the pump cuts in and builds up pressure, and s n and so fourth.
Old 01-12-2013, 04:26 PM   #3
Rewards Points: 91
your right my switch is a 40-60. so now to pull the pump and see wich line it is that leaks right?
Old 01-13-2013, 06:12 AM   #4
DIY staff
Rewards Points: 7,174
you need to call a well and pump company---pulling a well pump requires a hoist truck---dropping a pump and pipe into a well is a very expensive mistake---
Old 01-13-2013, 06:34 AM   #5
Rewards Points: 91
i dont need to cal anyone for this yet- i have replaced this well pump 2 times so far myself. i just need to pull the pump and line and pressure test it and hope the leak is in this section and not the one going thru the lawn to the house.
Old 01-13-2013, 06:38 AM   #6
DIY staff
That's great---Our area the wells are very deep and the work is beyond the capabilities of most homeowners.
Old 01-13-2013, 06:38 AM   #7
Rewards Points: 118
Replaced it two times over how many years?
Old 01-13-2013, 06:43 AM   #8
Rewards Points: 91
7. one pump replacement- and 1 pulled it to find the wites chaffed from the thrusting into pipe.... very acidic water by the way.
is my thought right about pulling line and putting air gauge on a side and capping other side and air chuck, filling with 30psi air and seeing if it leaks?
Old 01-13-2013, 07:34 AM   #9
Rewards Points: 3,130
Certainly can be. Several years ago, the day after I left for a military "adventure" in Central America, our water quit working. Somehow, the pump became detached from the piping and fell to the bottom of the well (about 400 feet). Fortunately, my wife found a well company that had invented its own special tool for "well fishing." They were able to retrieve the pump and reattach it. I didn't know about any of this until I came back home some months later.
The Following User Says Thank You to md2lgyk For This Useful Post:
oh'mike (01-13-2013)
Old 01-13-2013, 09:25 AM   #10
Rewards Points: 118
Yeah, it's probably the only way to know for sure. The check valve should hold, but getting a good seal on the adapter might be tough, so best bet is probably to test just the line. And I would definitely check the check valve as well.
Old 01-13-2013, 07:43 PM   #11
Rewards Points: 91
so i pulled the pump this morning- when i git it out the nipple out of the top of the pump that goes from the pump to the line had a large hole in it from corrosion. i replaced the nipple and put the pump back in and it is working fine now
The Following User Says Thank You to gwilkrrs For This Useful Post:
oh'mike (01-14-2013)
Old 01-13-2013, 08:22 PM   #12
Roofmaster
I guess where you heard it ain't where it was huh? Im from Maryland too, Finksburg. Also acidic water. Where are you located? I hope you put anti-torque spacers on the line, ran your power through PVC Pipe, and suspended your pump with a safety rope or chain. Wipe down your gear with bleach and water going in and put a cup of bleach down the well? Replace the O ring on the Pitless? What a neat Idea those are.
Old 01-14-2013, 05:35 AM   #13
Rewards Points: 91
i dont have a pitless connection- mine is in a 5'x5'x5' block bunker with a concrete lid.... i did put a thruster kit on it this time- why there wasnt one i will never know....... the pump is tied off, power and rope just run up with the line -no conduit.... i did put a steel (silver)nipple on since they didnt have a brass one so i guess i will get a brass one and put it on the shelf and wait....i just heard the water moving in the pipes i reckon- not a direct leak.... still have to figure out why the gauge is at 62- maybe the acid nuetralizer tech servicing the unit bled a touch of air out of the expansion tank? add a touch of air and we will see.....
manchester bu the way.......
Old 01-14-2013, 08:23 AM   #14
Roofmaster
You need a stainless steel nipple, not brass with acid water. Do you have a neutralizer tank? You are right up the road from me. Well, about 14 miles I guess. Water is very acidic. What Brand pump did you install and what HP. 250ft, you say? I will probably need a new pump soon. Ive done it once, No big deal. Have you seen the Pull-A-Pump? Really neat. All they have at Bens Rental are the ones with tires, dont look as good as the Pull-A-Pump check out U-Tube.
Old 01-14-2013, 09:50 AM   #15
Rewards Points: 1,648
The pump to pipe connection is probably a good place for a dielectric fitting to prevent electrolysis.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
