Well Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-27-2012, 04:42 PM   #1
Rewards Points: 730
Well Question
I have a 1HP submersible pump for my irrigation system. The pump is turned on via a pump start tied to my timer. My question is, is it possible to also add a small pressure tank to the system so that I could run a hose bib that bypasses the timer? If so, can you also tell me how this would be set up?
Master Brian is offline   Reply With Quote
Old 07-27-2012, 08:21 PM   #2
Rewards Points: 636
pump needs to hook to pressure switch which is then hooked to pressure tank,then timer gets hooked to a electric water valve down line from pressure tank along with hose bib
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
Master Brian (07-31-2012)
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
