Well Pump Wiring With Standard Control Box - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2010, 10:13 PM   #1
Well Pump wiring with standard control box
On a 5hp motor can you use a standard 5hp control box and wire the line 1 and 2 into a standard pressure switch and then to control box from there? Or is there too much amps on that pressure switch? Do i need a deluxe control box with contactor in it in order to use normal pressure switch?
plumbdoc is offline   Reply With Quote
Old 02-04-2010, 11:38 AM   #2
Rewards Points: 150
yes,you will need some type of motor contacts in which the pressure switch controls.
rudolph58 is offline   Reply With Quote
Old 02-04-2010, 08:09 PM   #3
Thanks Rudolph i kind of thought you needed a seperate contactor in order to hold the amount of juice going down to the motor. A well guy told me you can only control a 2 hp motor and smaller on a normal pressure switch (and with standard control box of course). Is this correct? Is there a certain size contactor box i should get for this 5 hp.
Old 02-04-2010, 08:13 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
a box rated for a 5 hp or greater motor.
the pump controller I see always seem to be rated for the pump HP.
Old 02-04-2010, 08:16 PM   #5
i have a 5 hp standard pump controller. it doesnt have a contactor in it. how do i wire the pressure switch to this control box
Old 02-04-2010, 08:31 PM   #6
nap
You talking to me?
nap's Avatar
didn't you just agree that you needed a pump controller WITH a contactor in it?
check the pressure switch. There should be rating right on it. If it is not rated for 5hp or more, you must use a controller with a contactor in it.
Old 02-04-2010, 08:35 PM   #7
yes i do agree. A standard box has no contactor. A deluxe box has a contactor in it. What i want to know is do they sell a seperate contactor box for the standard control box. Nap
Old 02-04-2010, 09:00 PM   #8
nap
You talking to me?
nap's Avatar
Ah, I misunderstood what you were asking.
I am not aware of a separate contactor box but if the room allows, there is no reason you could not incorporate a contactor in the controller that I can think of but to do it, or tell somebody how to do it, I would have to see the thing and any associated diagrams etc.
Old 02-04-2010, 09:27 PM   #9
thanks nap the customer had bought the standard box already just trying to see if i could use it. i will just tell them i we need a deluxe box.
American Standard Heritage 15 Heat Pump Tinkerer HVAC 9 12-22-2009 09:35 PM
Wiring a geothermal pump gfmonk Electrical 5 11-14-2009 02:30 PM
Sprinkler control wiring ScottR Electrical 9 06-26-2009 09:41 AM
Underground wiring to pump rolltested Electrical 10 04-29-2009 11:15 AM
Wiring limit control on gas boiler uncleneiler HVAC 2 11-21-2008 01:54 PM
