Well Pump Wires To Pressure Switch - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-30-2009, 07:56 PM   #1
well pump wires to pressure switch
I am working on a house that has a 4" well, there are 3 wires coming out, 1 red, 1 black and 1 yellow, could someone tell me how to wire it to a pressure switch, I am not sure if it is 120 or 240 volts, thanks !!!!
american501 is offline   Reply With Quote
Old 12-01-2009, 08:06 AM   #2
Remodeling Contractor
it needs 220V wiring. The extra wire is to handle the start up load. None of these are wired to the pressure switch. You need a starting controller first. Franklin makes a good one.
Old 12-01-2009, 09:09 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
how did you determine it is a 240 volt pump?
while it most likely is, there is a possibility it could be a 120 volt pump and until the OP determines which it is, it would not be good to power it with the wrong voltage.
american: how did you end up with a pump in a well and no control box and no idea the voltage of the pump?
Old 12-01-2009, 09:37 AM   #4
I never saw a well pump on 110V that used a starting current motor... did you? Most are done this way. A smaller unit if on 110V would also not likely need the starting current wiring.
Old 12-01-2009, 09:37 AM   #5
Water quality'n pump guy
Three wires may mean a 3 wire pump that requires a control box. The control box has to be the right size for the hp of the pump. I'm not sure, I'm having on of those mental thingies... are there 120v 3 wire pumps?
Or, three wires may mean that someone may have bought three wires for a 2 wire pump and the red was used for ground, although it should have been green.
Gary Slusser
23 years in water treatment and well pumps, 13 years on the 'net helping others to help themselves.
Gary Slusser is offline   Reply With Quote
Old 12-01-2009, 06:48 PM   #6
nap
You talking to me?
nap's Avatar
yes there are 120 volt cap start cap run motors. Here is a page with some Myers submersible CSCR motors:
http://www.wwpp.com/products/myers/p...mps3.htm#5gpm3
and yes, the box can vary according to the HP rating. The caps, especially, need to be properly sized.
OP definately needs more info before he hooks this thing up.
I would start with finding out how deep the well is and how deep the pump is set. Shallower pumps, to a certain depth, can be pulled by hand without too much difficulty. A really deep pump is a different story.
Either one can take a finger off if done incorrectly.
Old 12-02-2009, 02:29 PM   #7
Do you know the make and model of the pump?
hayewe farm is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
Could a failed condensor fan raise pressure/trip high pressure limit switch? (Rheem) hennyh HVAC 6 07-30-2009 02:04 PM
Identifying wires in a three way switch bergs4 Electrical 15 07-29-2009 10:33 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 05:53 PM
