-   -   well pump wires to pressure switch (http://www.diychatroom.com/f7/well-pump-wires-pressure-switch-58227/)
american501 11-30-2009 07:56 PM
I am working on a house that has a 4" well, there are 3 wires coming out, 1 red, 1 black and 1 yellow, could someone tell me how to wire it to a pressure switch, I am not sure if it is 120 or 240 volts, thanks !!!!
Bob Mariani 12-01-2009 08:06 AM
it needs 220V wiring. The extra wire is to handle the start up load. None of these are wired to the pressure switch. You need a starting controller first. Franklin makes a good one.
nap 12-01-2009 09:09 AM
how did you determine it is a 240 volt pump?
while it most likely is, there is a possibility it could be a 120 volt pump and until the OP determines which it is, it would not be good to power it with the wrong voltage.
american: how did you end up with a pump in a well and no control box and no idea the voltage of the pump?
Bob Mariani 12-01-2009 09:37 AM
I never saw a well pump on 110V that used a starting current motor... did you? Most are done this way. A smaller unit if on 110V would also not likely need the starting current wiring.
Gary Slusser 12-01-2009 09:37 AM
Three wires may mean a 3 wire pump that requires a control box. The control box has to be the right size for the hp of the pump. I'm not sure, I'm having on of those mental thingies... are there 120v 3 wire pumps?
Or, three wires may mean that someone may have bought three wires for a 2 wire pump and the red was used for ground, although it should have been green.
nap 12-01-2009 06:48 PM
yes there are 120 volt cap start cap run motors. Here is a page with some Myers submersible CSCR motors:
http://www.wwpp.com/products/myers/p...mps3.htm#5gpm3
and yes, the box can vary according to the HP rating. The caps, especially, need to be properly sized.
OP definately needs more info before he hooks this thing up.
I would start with finding out how deep the well is and how deep the pump is set. Shallower pumps, to a certain depth, can be pulled by hand without too much difficulty. A really deep pump is a different story.
Either one can take a finger off if done incorrectly.
hayewe farm 12-02-2009 02:29 PM
Do you know the make and model of the pump?
