Old 08-20-2011, 12:49 PM   #1
well pump testing
how do you know if your well pump is operating.I have no water pressure and have replaced pressure switch on tank. When i plug it in nothing happens.
akeelam72 is offline   Reply With Quote
Old 08-20-2011, 09:20 PM   #2
well pump testing
What type of pump do you have jet pump, shallow well, deep well? Is there a pressure gauge anywhere and if so what is the reading on it? Has a main shut off valve been accidently turned off? I assume you checked the breaker?
daveb1 is offline   Reply With Quote
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 05:35 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Sump Pump Questions henlij Plumbing 19 08-12-2009 08:50 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
