Old 06-16-2010, 12:20 PM   #1
well pump spins at top...breaker caught fire when I turned it on
We had our well pump worked on 11 days ago...the man unclogged the foot and replaced wires...now pump wont work...you can turn the top of the pump a little....I wanted to hear what it was doing so i could explain it when i call the pump man,so i turned on the breaker and flames started coming out at the breaker in breaker box..I turned it right back off....then went to look at the pump....where he spliced to put attatch new wires there is about 2 in of wire that isn't in the little plastic thingy that covers the wire nuts....the ground wire isn't covered at all in that 2 in space and the 2 110's only look like they have a thin piece of burnt saran wrap (that thin)could this cause a problem?
kim4875 is offline   Reply With Quote
Old 06-16-2010, 05:45 PM   #2
Licensed Master Plumber
zounds like you have a dead short in the motor wiring that needs to be spliced properly.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 06-16-2010, 08:16 PM   #3
It was a dark and stormy
Yoyizit's Avatar
Breaker was bad or had bad connections. It's bad now, fer' sure. You may want to get a breaker with a trip curve that matches what is recommended for your pump.
Old 06-17-2010, 02:55 PM   #4
Owner
LateralConcepts's Avatar
I think you need an electrician. Not a plumber.
LateralConcepts is offline   Reply With Quote
Old 06-17-2010, 05:23 PM   #5
We had our well pump worked on 11 days ago...the man unclogged the foot and replaced wires...now pump wont work...you can turn the top of the pump a little....I wanted to hear what it was doing so i could explain it when i call the pump man,so i turned on the breaker and flames started coming out at the breaker in breaker box..I turned it right back off....then went to look at the pump....where he spliced to attach new wires there is about 2 in of wire that isn't in the little plastic thingy that covers the wire nuts....the ground wire isn't covered at all in that 2 in space and the 2 110's only look like they have a thin piece of burnt saran wrap (that thin)could this cause a problem?
Probably not the breaker
How to find out why your pool pump is not fully priming tripflex How To Guides 6 07-13-2011 07:31 PM
Fire Pump Bypass FIA Ranch Electrical 31 01-17-2010 04:22 PM
My blower motor caught fire JackKarnes HVAC 16 07-17-2009 03:24 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 09:38 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 08:48 PM
