Well Pump, Pressure Tank Issue?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2011, 03:34 PM   #1
well pump, pressure tank issue??
Hoping someone could shed some light on this situation. We have a building that has been vacant for some time. It has a well, jet pump and 4 gallon pressure tank. Because it was vacant, we shut off the pump and emptied the pressure tank. Months later we wanted to get the system going again. We turned on the pump and it ran for 30 mins and the pressure would not move off of 0 psi. The gauge is on the pump. I'm at a loss why the pump would continue to run and not build up any pressure. Could the pressure tank be depressurized? Any help or tips to get the pressure back up to 20 to 40 psi would help.
I also primed the pump, but not sure I did it properly. Added about 1/2 a gallon or so to the pump.
Thanks.
fumbrunner is offline   Reply With Quote
Old 11-26-2011, 04:08 PM   #2
Rewards Points: 22
Well, I'm not the guy to tell you how to prime it, because I had one 30 years ago, and had a heck of a time priming it sometimes, so not sure that I was always doing it right either, but, although I obviously know nothing about the condition of your tank, I would suspect the prime before the tank.
Old 11-26-2011, 09:51 PM   #3
Rewards Points: 1,418
If you are not getting any water out of open faucets then the problem is back at the pump and has nothing to do with the pressure tank.
MasterCraft shallow well pump not happy rtoni Plumbing 7 06-06-2011 12:41 PM
well pressure tank leak wengang1 Plumbing 16 10-07-2010 09:59 AM
Rain Collection System Using Collection Tanks in Multiple Locations Gheuett Landscaping & Lawn Care 10 09-15-2010 09:30 AM
amtrol pressure tank pump is shutting on and off shulsbos Plumbing 3 08-01-2010 09:53 AM
Pressure switch issue? or something else... rp4985 Plumbing 8 07-11-2009 03:31 PM
