Old 09-19-2012, 10:33 AM   #1
well pump pressure going down
hi everyone, i am a pretty much do it yourselfer, but am having a problem with my well pump pressure going down to like 25 psi and then kicking back up to 55 psi ,and there is no water being run anywhere . would like some feedback if possible
upscar88man is offline   Reply With Quote
Old 09-19-2012, 10:36 AM   #2
A "Handy Husband"
rjniles's Avatar
Start a new thread in the plumbing section.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 09-19-2012, 10:37 AM   #3
Upscar, go back and post your own question, and post it in the plumbing area this time.
Also it's always best to add your location in your profile for better ansewers.
Old 09-19-2012, 01:59 PM   #4
the Musigician
DangerMouse's Avatar
With nothing running, I'd guess bad check valve.
DM
(I moved this to plumbing for you.)
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
mrsolowill (09-20-2012)
Old 09-19-2012, 02:16 PM   #5
You obviously have a leak, whether at the check valve, as DM mentioned, the line from the well to the house, or within the house. I would start by closing the valve after the tank, then watching the gauge, and you should be able to determine which side of that the leak is on. Do you have a submersible or jet pump? More details will result in more relevant replies.
Old 09-19-2012, 09:30 PM   #6
bad check valve or hole in pipe from well to holding tank...
irrigation pump pressure switch melted irrigation Electrical 2 09-02-2012 07:49 PM
Replace pressure washer pump schibbs Tools 3 05-26-2012 09:49 AM
Craftsman Pressure Washer 580.761800 pump question SteveLake Tools 0 06-22-2011 10:51 PM
water pressure no staying after pump shuts off mjrosa Plumbing 3 03-20-2011 11:09 PM
pressure switch on pump radams3141 Plumbing 2 04-30-2008 08:14 PM
