-   -   well pump pressure going down (http://www.diychatroom.com/f7/well-pump-pressure-going-down-157299/)
upscar88man 09-19-2012 10:33 AM
hi everyone, i am a pretty much do it yourselfer, but am having a problem with my well pump pressure going down to like 25 psi and then kicking back up to 55 psi ,and there is no water being run anywhere . would like some feedback if possible
rjniles 09-19-2012 10:36 AM
Start a new thread in the plumbing section.
joecaption 09-19-2012 10:37 AM
Upscar, go back and post your own question, and post it in the plumbing area this time.
Also it's always best to add your location in your profile for better ansewers.
DangerMouse 09-19-2012 01:59 PM
With nothing running, I'd guess bad check valve.
DM
(I moved this to plumbing for you.)
DexterII 09-19-2012 02:16 PM
You obviously have a leak, whether at the check valve, as DM mentioned, the line from the well to the house, or within the house. I would start by closing the valve after the tank, then watching the gauge, and you should be able to determine which side of that the leak is on. Do you have a submersible or jet pump? More details will result in more relevant replies.
ben's plumbing 09-19-2012 09:30 PM
bad check valve or hole in pipe from well to holding tank...:yes:
