Well Pump Not Gaining Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-23-2012, 08:29 AM   #1
Well pump not gaining pressure
Hello all. I've been battling this well system for over a week. It is a shallow well 1/2 hp Jet pump. It started when I was moving some stuff and bumped the pipe leading out of it, it cracked the coupler going into the pump head and sprang a leak. I took it out, chipped out the old brass, retapped it and put it back together. Turned on the pump (It sits below the well level so no priming necessary) and went an burped all the fixtures. It ran and ran but wouldn't shut off. I figured when I was cleaning the broken metal out some got in and wore the pump.
Me being a cheapskate, I picked up a pump from a lady who said it had 3 months of use, she also gave me a new pressure tank just as new. I installed these and fired it up. Same results. Only 43 psi. so it is not tripping the pres. switch. Both seemed to be running smooth. I didn't change anything else in the system so i am just checking if there is something else I could be overlooking before I go and drop more money on a new pump.
Offalot is offline   Reply With Quote
Old 10-23-2012, 08:40 AM   #2
Rewards Points: 14,300
Bad foot valve in the well or check valve in the line, leaking suction line can all cause this.
Old 10-23-2012, 09:35 AM   #3
I have had a bad check valve before. It caused the pump to reach the shut off pressure (~60psi)then click on and off repeatedly as PSI bounced up and down from shut off to turn on pressure. If it were stuck open I would think it would still get above 43 psi, or am I not thinking of this the right way?
Old 10-23-2012, 10:38 AM   #4
joed's Avatar
Rewards Points: 13,710
Failure to build pressure has in experience always been cause by a piece of debris in the jet orifice. Usually builds between 30-40 psi and sits there running.
Old 10-23-2012, 01:11 PM   #5
That is what it is doing. How do I access the jet orifice? Do I have to take the whole head apart?
Also may be worth mentioning, I only have 1 line in from the well. The pump I bought has two ports on the face. I plugged the lower one. I read that is a pressure side for extra pumping. Didn't know if that might affect anything but figured I should mention it in case.
Old 10-23-2012, 02:30 PM   #6
joed's Avatar
The one I have worked on look like this. Never seen one with two ports. Remove two bolts and the nozzle comes of and flush it with water.
irrigation pump pressure switch melted irrigation Electrical 2 09-02-2012 06:49 PM
Well Pump Pressure Problems LTY83 Plumbing 15 06-30-2012 02:58 PM
Replace pressure washer pump schibbs Tools 3 05-26-2012 08:49 AM
Craftsman Pressure Washer 580.761800 pump question SteveLake Tools 0 06-22-2011 09:51 PM
pressure switch on pump radams3141 Plumbing 2 04-30-2008 07:14 PM
