Well Pump Motor Burns Out 3 To 5 Times A Year - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-19-2009, 07:22 PM   #1
Well Pump motor burns out 3 to 5 times a year
Water Pump burns out every 3-4 months what should I do to fix this situation
thomas921 is offline   Reply With Quote
Old 11-19-2009, 07:29 PM   #2
Where is it located?
What kind of well?
What kind of pump?
What power is going to the pump ?
Who's been replacing it & what trouble shooting have they done?
Old 11-19-2009, 07:46 PM   #3
It is a submersible pump with 220 volts running to it and I have been replacing it for my father in law. He hasn't done any repairs besides replacing it.
Old 11-19-2009, 11:32 PM   #4
Could be you need a deeper well because it is being pumped dry. You might be able to add a retriggerable timer relay so it won't run as long if there is a problem.
hayewe farm is offline   Reply With Quote
Old 11-20-2009, 03:27 PM   #5
Water quality'n pump guy
You have an electrical problem and need to check the electrical cable etc. to the pump. You culd also be suffering from short cycling of the pump where it leads to overheating of the motor so check the air pressure in the pressure tank with no water in it, it should be 1-2 psi less than the turn the pump on switch setting..
http://www.franklin-electric.com/bus...M/page-13.aspx
Gary Slusser
23 years in water treatment and well pumps, 13 years on the 'net helping others to help themselves.
Gary Slusser is offline   Reply With Quote
Exterior grade sump pump Jeeper1970 Plumbing 11 12-02-2016 11:17 AM
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 08:46 AM
How to find out why your pool pump is not fully priming tripflex How To Guides 8 07-15-2015 06:15 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 07:13 PM
