Well Pump Keeps Triping Breaker - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2010, 02:09 AM   #1
well pump keeps triping breaker
well pump keeps tripping breaker I believe it a franklin 3/4 hp 230v pump with a control box. control box buzzes then breaker trips within 5 secs. I took some ohms readings with pump disconected from box blk - yel= 1.6 ohms red - yel 11.5 ohms red- blk = 10 ohms. black- ground= 2 ohms red-grd= 11.7 ohms yel-grd=2.4 ohms I would appreciate any input
ajmacd845 is offline   Reply With Quote
Old 04-26-2010, 02:25 AM   #2
you may need an amprobe to determine if the motor is locked up. can you access any part of the motor to see if it spins by hand? the pump itself may be seized preventing the motor from starting.
also could have a start capacitor in the control box thats bad,(round black plastic thing with 2 wires)
kennzz05 is offline   Reply With Quote
Old 04-26-2010, 02:42 AM   #3
I do have an amprobe dont no how to tell if its locked. I checked the ohms on the capacitor and it seemed to be good. pump was working fine all day then just tripped the pump is still at bottom of the well so cant get to it
Old 04-26-2010, 02:58 AM   #4
put amprobe around one of the supply voltage wires feeding the pump set it on whatever scale exceeds the rating of the breaker like 0-50 amps apply power if the amp draw exceeds the breakers rating than you know the motor/pump is the problem.Whats located inside the control box you mentioned?
really need a analog ohmeter with a1000k scale to read a cap it will peg the meter than gradually drop some newer meters have a mfd scale and it will actually give you the mfd rating of the cap
Old 04-26-2010, 03:13 AM   #5
In the box is a blue start relay and the capacitor i think the start relay is what is buzzing Iam gonna pick up a analog meter in morning i only have digital
Old 04-26-2010, 03:17 AM   #6
you might as well buy a new cap it may be cheaper we are speaking of a start cap correct? black,round,plastic? not oval and metal(run cap)
Old 04-26-2010, 11:26 AM   #7
Water quality'n pump guy
Use this to troubleshoot before you start replacing parts.
http://www.franklin-electric.com/bus...M/page-13.aspx
Gary Slusser
23 years in water treatment and well pumps, 13 years on the 'net helping others to help themselves.
Gary Slusser is offline   Reply With Quote
How to find out why your pool pump is not fully priming tripflex How To Guides 8 07-15-2015 06:15 AM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
Voltage dip when sump pump starts Josh61513 Electrical 4 04-03-2009 11:32 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
