Well Pump Doesn't Work After Power Outage - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-30-2012, 02:18 PM   #1
Rewards Points: 173
Well pump doesn't work after power outage
Dear experts,
We just went through a power outage. Yesterday, I ran a power generator, and was able to use my water well. This morning I tried it again, and the well pump didn't work. Now power is back, but the pump still is not working. I tried to turn the pump power switch on and off, without success.
Could you please help me with this?
Thanks.
dpreznik is offline   Reply With Quote
Old 10-30-2012, 02:54 PM   #2
Rewards Points: 610
tere is a small lever on side of pressure switc...old it up to enerize pump until preessure baclk up ..sorry puter probs wit some letters
techpappy is offline   Reply With Quote
The Following User Says Thank You to techpappy For This Useful Post:
dpreznik (10-30-2012)
Old 10-30-2012, 03:04 PM   #3
Rewards Points: 173
Unfortunately, I don't have that lever on that switch...
Old 10-30-2012, 04:41 PM   #4
Rewards Points: 610
shut power(breaker or pull fuse) .. remove cover from press switch.then turnpower back on hold contactor in with piece of wood to energize pump until pressure is reached...turn power back off to replace cover then turn power back on ..
NOTE you can use insulated pliers or screw driver as long as you don't touch side of enclosure while holding contacts in..also ..contactor rocks back and forth..hold to one side to close the open contacts...hope this helps
Tags
well water pressure pump
Running boiler during power outage? jmhultin HVAC 7 10-31-2011 11:28 AM
Lennox A/C not working after power outage. Tri Boyer Appliances 0 08-24-2011 02:43 PM
Power 120V Pump from a 240V circuit RoberTX Electrical 26 07-05-2011 11:43 PM
Power outage at least once per month? imola ghost Electrical 7 08-30-2010 10:17 PM
Need help with water pump power Marc10edora Electrical 15 05-13-2007 07:08 PM
