-   -   Well pump doesn't work after power outage (http://www.diychatroom.com/f7/well-pump-doesnt-work-after-power-outage-161639/)
dpreznik 10-30-2012 03:18 PM
Dear experts,
We just went through a power outage. Yesterday, I ran a power generator, and was able to use my water well. This morning I tried it again, and the well pump didn't work. Now power is back, but the pump still is not working. I tried to turn the pump power switch on and off, without success.
Could you please help me with this?
Thanks.
techpappy 10-30-2012 03:54 PM
tere is a small lever on side of pressure switc...old it up to enerize pump until preessure baclk up ..sorry puter probs wit some letters
dpreznik 10-30-2012 04:04 PM
Unfortunately, I don't have that lever on that switch...
techpappy 10-30-2012 05:41 PM
shut power(breaker or pull fuse) .. remove cover from press switch.then turnpower back on hold contactor in with piece of wood to energize pump until pressure is reached...turn power back off to replace cover then turn power back on ..
NOTE you can use insulated pliers or screw driver as long as you don't touch side of enclosure while holding contacts in..also ..contactor rocks back and forth..hold to one side to close the open contacts...hope this helps
