Well Pump With Chemical Holding Tank Irrigation System - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-05-2012, 01:01 PM   #1
Well pump with chemical holding tank Irrigation System
My 30 gal holding tank with rid-a-rust chemicals appears to have drained back into the irrigation system just after 1 use (approx 2 hour run time). I'm told this may have been caused by a reverse pressure situation and that the check valve may have gone bad. Any advice?
fkgates is offline   Reply With Quote
Old 06-05-2012, 10:56 PM   #2
A check valve isn't going to cut it. You'll need to have a backflow preventer installed, ie- reduced pressure backflow preventer (aka RP backflow preventer). Or maybe a double check backflow preventer.
Check with the local authorities as they will best to provide with what's required in your area.
When harmful or potentially deadly items may get added to the potable water, such as in your case, you must address this properly and without delay.
Quick question. What else is isolating your boiler from the house's water supply? What I'm getting at is how did this reverse pressure system backflow into the irrigation system and not the whole house?
VIPlumber is offline   Reply With Quote
Old 06-06-2012, 08:01 AM   #3
What I didn't state earlier is that this system worked well for 2 years. It was only this spring when I started it up that I had the back flow problem.
Seems something has failed in the system to cause my 30 gallon holding tank to drain into the system.
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
New Well, Pump & Pressure Tank Daneel Electrical 3 06-08-2011 04:39 PM
MasterCraft shallow well pump not happy rtoni Plumbing 7 06-06-2011 12:41 PM
Aerator pump size for septic tank spaceman spif Plumbing 9 03-17-2011 12:40 PM
Well Water System Problem browning Electrical 6 09-12-2010 07:14 PM
