Well Pressure Tank Not Holding At 60 Psi - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-10-2013, 10:22 AM   #1
well pressure tank not holding at 60 psi
Hi, I'm new to the site.
My well is doing the following:
If I turn off the breaker, then turn back on, the pump presses the pressure tank up to 60 psi. The switch then turns the pump off. Then the pressure in the tank starts to drop (no water running) to 40. A whistling sound seems to be coming from the tank. The switch turns on the pump, the pump gets the pressure up to 50 but goes no higher so the pump stays on.
I have:
replaced the switch and gauge
checked air pressure in tank (38 psi no water spitting out)
checked for leaks in well ( no water at connection where well pipe attaches to horizontal pipe running to house)
found no water leaks in house ( house is 11 years old)
good water pressure, no pulsing.
Also, a few days ago, the pump would press the tank up to 60 psi and the pressure would stay there until we used water. Now it won't stay at 60 so we shut it off when we aren't using water.
Any Ideas? Thanks
sailor dave is offline   Reply With Quote
Old 09-10-2013, 12:39 PM   #2
Water Treatment
Rewards Points: 812
The check valve in the pump called the foot valve is bad.
One could put a second check valve right at the pressure tank, just before the tank to hold the pressure at the tank.
Akpsdvan is online now   Reply With Quote
Old 09-10-2013, 03:31 PM   #3
joed's Avatar
Rewards Points: 11,536
A bad check valve would account for the loss of pressure. The lack of ability to build past 50 psi could be a separate issue.
What type of pump do you have? jet pump? deep or shallow setup? submersible? piston pump?
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
Boiler pressure relief valve problem maddog1 Plumbing 25 12-22-2012 08:35 AM
Pressure tank cycling sontavas Plumbing 8 12-10-2012 08:04 PM
Question about well pressure tank Bahuffma General DIY Discussions 6 05-16-2011 03:23 PM
New tank new pump, no pressure?? Toyz Plumbing 2 07-26-2008 08:38 AM
