Well Pressure Tank Issues - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2014, 09:25 PM   #1
Well pressure tank issues
I have a constant pressure well system with a jet rite 2 pressure tank. The system froze up but now I do have water in the house. The problem I am having is the water is running at 125 psi and the system is set for 50 psi. Could this be the result of my pressure tank being frozen?
bigen70 is offline   Reply With Quote
Old 02-10-2014, 09:30 PM   #2
Master Plumber
Benplumbing's Avatar
There should be a sensor that Senses the pressure. Sounds like that might be failing even if your pressure tank bladder is shot the system still should recognize the current psi and shut off to the appropriate setting. Or the pressure gauge is busted.. Either way still might be good to have a professional look at it constant pressure control boxes can be kind of hairy
Benplumbing is offline   Reply With Quote
Old 02-12-2014, 10:53 AM   #3
Rewards Points: 1,989
Most / all the wells I have worked on had a pressure switch , kind of like this
http://www.supremewatersales.com/squ...FSUS7Aod1GQASw
Check to see if the fitting where the pressure switch connects to the water line , is frozen ?
Can you hear the well running continuously / not shutting off ?
Or , as has been suggested , the gauge may be defective ? ( or frozen also ? )
God bless
Wyr
WyrTwister is offline   Reply With Quote
Old 02-12-2014, 10:38 PM   #4
I'm with WyrTwister. The 1/4" tube that leads up to the pressure switch may still be frozen, and as a result the switch isn't getting a proper reading of the pressure. Ice and thawing also tend to free dirt, rust, scale etc from the inside of the pipes, so it's possible the pressure switch is clogged with all that gunk, too.
Ishmael is offline   Reply With Quote
Tags
pressure tank
Need Help on Well Pressure Tank Layout osubuckeye88 Plumbing 16 02-04-2014 07:02 AM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 08:37 AM
I think my plumber installed my pressure tank incorrectly. lierman44 Plumbing 11 10-19-2012 09:37 PM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 10:29 AM
Well Pressure Tank - Maintenance? edro Plumbing 5 12-15-2010 11:23 PM
