Old 08-21-2011, 10:47 AM   #1
Well pressure boost for lawn irrigation system.
I have a well installed for lawn irrigation. It is a 26' deep sand point well. It doesn't appear to be putting out sufficient pressure to cover the sprinkler areas. I don't believe the prior owners ever pulled the pump to perform maintenance or winterize. Is there any maintenance that can be performed to increase pressure, or is there any kind of jet pump or booster I can add?
wernerp is offline   Reply With Quote
Old 08-21-2011, 10:50 AM   #2
I also do not have a pressure tank installed. The well pump discharges directly to the sprinkler system.
Old 08-21-2011, 05:53 PM   #3
plumbing,softener,well
the first question i have for u is how old is the pump? another question is what size is ur pump? i have a similar set up at my house and i have a pressure tank and switch controlling the well so i can regulate the pressure alot more. you could be dealing with a simple problem that ur pump doesnt deliver enough water because ur pump is to small of a gpm pump. but there is alot that goes into sizing a pump for a well. if u put a pump in that is to big them u take a chance of pumping ur well off. i would find out the gpm of the zones in ur irrigation and make sure that ur irrigation isnt trying to use more water than ur pump can deliver. if that is the problem there are many different solution to that problem. the fastest solution would to be to change out the nozzles on ur sprinkler heads and adjust the time that they run to make sure for proper irrigation.
plumberboy69 is offline   Reply With Quote
Old 08-21-2011, 06:03 PM   #4
Thank you, I will look into it. I believe the pump is about 3 years old. The previous owner installed a couple of years before I bought the place.
Old 08-21-2011, 06:14 PM   #5
Doing it myself
Alan's Avatar
If it doesn't have a pressure tank, what keeps the pump from burning up? IE : What controls the on/off points?
Journeyman Plumber
Old 08-22-2011, 07:50 AM   #6
if u have a controller on the sprinkler system the controller can be set up to make the pump turn on and off as needed.
Old 08-22-2011, 10:00 AM   #7
Doing it myself
Alan's Avatar
So the pump just runs continually while irrigation is turned on???
Journeyman Plumber
Old 08-22-2011, 02:57 PM   #8
yeah it sure sounds that way from what u r saying. it is usually done like that on real big irrigation systems like small industrial or commercial.
Old 08-22-2011, 11:33 PM   #9
Doing it myself
Alan's Avatar
Yes, but THOSE kinds of systems usually have a much larger flow/recovery requirement, upwards of 30 GPM or even more, in order to keep the pump in water.
In a residential well, i'd say it would be safe to assume that the well recovery rate may not be enough to keep up with the demand of the irrigation.
BUT : without knowing specifics on the well itself, and the type of irrigation being supplied by said well, it's impossible really to figure out how much water is actually there.
Especially considering that some people consider "low flow" to be low pressure.
The pump may be pumping all the water it can, and there just aint no more.
Journeyman Plumber
Boiler pressure troubles jduffett HVAC 2 12-12-2010 08:15 AM
Unsafe irrigation systems....? Why bother? Hossenfeffer Landscaping & Lawn Care 17 08-24-2010 03:14 PM
repairing irrigation system rpsally777 Landscaping & Lawn Care 1 11-08-2009 04:38 AM
Whoa, how much water can my irrigation system use??? J187 Landscaping & Lawn Care 19 11-10-2008 04:04 PM
Pressure Testing the Filter system, What meter to get? zootjeff HVAC 1 07-12-2007 12:58 PM
