-   -   Well pressure boost for lawn irrigation system. (http://www.diychatroom.com/f7/well-pressure-boost-lawn-irrigation-system-114774/)
wernerp 08-21-2011 09:47 AM
I have a well installed for lawn irrigation. It is a 26' deep sand point well. It doesn't appear to be putting out sufficient pressure to cover the sprinkler areas. I don't believe the prior owners ever pulled the pump to perform maintenance or winterize. Is there any maintenance that can be performed to increase pressure, or is there any kind of jet pump or booster I can add?
wernerp 08-21-2011 09:50 AM
I also do not have a pressure tank installed. The well pump discharges directly to the sprinkler system.
plumberboy69 08-21-2011 04:53 PM
the first question i have for u is how old is the pump? another question is what size is ur pump? i have a similar set up at my house and i have a pressure tank and switch controlling the well so i can regulate the pressure alot more. you could be dealing with a simple problem that ur pump doesnt deliver enough water because ur pump is to small of a gpm pump. but there is alot that goes into sizing a pump for a well. if u put a pump in that is to big them u take a chance of pumping ur well off. i would find out the gpm of the zones in ur irrigation and make sure that ur irrigation isnt trying to use more water than ur pump can deliver. if that is the problem there are many different solution to that problem. the fastest solution would to be to change out the nozzles on ur sprinkler heads and adjust the time that they run to make sure for proper irrigation.
wernerp 08-21-2011 05:03 PM
Thank you, I will look into it. I believe the pump is about 3 years old. The previous owner installed a couple of years before I bought the place.
Alan 08-21-2011 05:14 PM
If it doesn't have a pressure tank, what keeps the pump from burning up? IE : What controls the on/off points?
plumberboy69 08-22-2011 06:50 AM
if u have a controller on the sprinkler system the controller can be set up to make the pump turn on and off as needed.
Alan 08-22-2011 09:00 AM
So the pump just runs continually while irrigation is turned on??? :eek:
plumberboy69 08-22-2011 01:57 PM
yeah it sure sounds that way from what u r saying. it is usually done like that on real big irrigation systems like small industrial or commercial.
Alan 08-22-2011 10:33 PM
Yes, but THOSE kinds of systems usually have a much larger flow/recovery requirement, upwards of 30 GPM or even more, in order to keep the pump in water.
In a residential well, i'd say it would be safe to assume that the well recovery rate may not be enough to keep up with the demand of the irrigation.
BUT : without knowing specifics on the well itself, and the type of irrigation being supplied by said well, it's impossible really to figure out how much water is actually there.
Especially considering that some people consider "low flow" to be low pressure.
The pump may be pumping all the water it can, and there just aint no more.
