Well Pipe Size & Pressure Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2012, 05:33 PM   #1
Well pipe size & pressure question
Installing a whole house strainer, filter and acid neutralizer system. I have a question about pipe size. I currently have 3/4" black poly coming in from well, (12gpm) and the inlet/outlets of the filter control valves are 1". What effects will I see if I go from 3/4" well line to a 1" loop for filtration, then reduced back down from 1" to 3/4" at the tee for the cold main in the house? I was told that a 1" filter control valve would allow greater flow rates but I wonder if that will hurt pressure? I thought making the filtration loop 1" would be good for future well & water line upgrades. (I also thought I had a 1" line coming in from my well when I bought everything, my mistake)
ncrango is offline   Reply With Quote
Old 02-22-2012, 05:44 PM   #2
Rewards Points: 582
well those are well founded thougths ..imo Iwould just reduce inlet for filter from 1" to 3/4 should be fine....
The Following User Says Thank You to ben's plumbing For This Useful Post:
jaydevries (02-22-2012)
Build up in cast iron pipe bend -> new high pressure toilet to fix? VTJeff99 Plumbing 3 02-09-2012 01:05 PM
replace a pice of pipe, how to properly shut off/vent pressure langless28 HVAC 1 01-11-2012 11:56 AM
Furnace pressure switch line/nipple question aparman HVAC 4 12-31-2011 04:27 PM
Ground Wire Size Question Suprageezer Electrical 12 07-28-2011 03:00 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
