Well Is Not Working Maybe Frozen Maybe Pump Broke...help... - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2010, 01:42 PM   #1
Well is not working maybe frozen maybe pump broke...help...
Well has stopped working since yesterday. Thought was frozen but put a heat light in it for 2 days still no water. Pump is not running but had power to it and power to the regulator.
DoubletakeBulls is offline   Reply With Quote
Old 12-16-2010, 01:47 PM   #2
Has been bitter cold here for 2 weeks.
Old 12-16-2010, 03:52 PM   #3
Rewards Points: 120
Submersible, or what? How are you checking power to it? Is it 220? Are both legs "live"? By regulator, do you mean pressure switch? Is the line from the pump to the building possibly frozen? Not uncommon for the line to freeze along the side of and where it enters the building. I have to go to a meeting, but with some more information, it is very likely that someone can give you some ideas.
Old 12-16-2010, 07:31 PM   #4
Water Treatment
Rewards Points: 900
Is the pressure switch open? like it has the pressure that it needs?
Just found one the other day that the 1/4 nipple between the switch and the tank Tee was froze, removed the ice with turbo torch and the switch started working again..
Akpsdvan is offline   Reply With Quote
Old 12-16-2010, 07:33 PM   #5
It is a submersible pump which has 2-110v screw in fuses. I checked it with a electricity current tester. All has power and appears to be working. i think the pump is burnt but how do I know without pulling it out and replacing it? Can it be the regulator thing that turns off and on?
Old 12-16-2010, 10:56 PM   #6
Water Treatment
Rewards Points: 900
It is possible that the well control box resister is bad..
Did you check the pressure switch to make sure that it is working? that it is closed right now? or is it open right now?
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Well pump wiring, the correct guage? lennyjay Electrical 3 08-18-2009 12:53 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Well pump issue-should I be concerned? Mikedks Plumbing 8 10-08-2006 10:42 PM
heat pump not working kyleGR HVAC 2 05-30-2006 02:35 PM
