Well Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2012, 08:51 AM   #1
Well lines
How to locate existing water line from well. Replacing Mobile Home.
adrian13267 is offline   Reply With Quote
Old 10-15-2012, 08:58 AM   #2
Rewards Points: 13,300
What type well? Is the pump in the well?
If not then your going to have to just look at where it entered the home and hope they just dug a straight trench to the well and start digging.
Old 10-15-2012, 07:04 PM   #3
try witching them. use two coathangers bent into a L and hold the short end in each hand when they cross you will have found your water line. Dosent work for everyone, but works for me.
merle is offline   Reply With Quote
Old 10-15-2012, 07:52 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
merle,
do you sand paper the part of the metal coat hanger you hold to remove any plastic/sealant from the hanger?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-16-2012, 07:24 PM   #5
No I never have, I just cut them and bend them into a L shape. You can sand them if you so desire tho.
Old 10-17-2012, 08:51 AM   #6
joed's Avatar
Rewards Points: 12,008
Metal lines? Use a metal detector or line tracer.
Plastic lines? Feed a wire or metal snake down the line and use the line locator.
Submersible pump? Trace the electric wires.
wall out of plumb how do you tile it and have decent visuals. grout lines off by 1/4 papason Tiling, ceramics, marble 2 08-11-2012 03:46 PM
Connect Air Cond Drain to House Waste lines AdamOJ Plumbing 19 11-23-2011 07:47 AM
Low point in water supply lines dave11 Plumbing 3 02-01-2011 08:13 PM
slow hot water lines sobro Plumbing 3 11-05-2010 11:44 AM
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 06:02 AM
