well house plumbing
Thanks for the replies everyone.i have a question that may have an easy answer but i don't know it. I have a [ water ace submersible well pump , 2 wire , 3/4 horse , 230 volts , 10gbm ]
[ a new utilitech pro tank , 25 gallon , factory precharge is 25 psi , ] , [ a new 30-50 psi pressure switch , which is adjustable ] and [ a new 75 lb pressure relief valve. ] my question is what is a good pressure to run the well system or what is my pump's start-up pressure.i'm thinking there needs to be harmony between the 4 parts ?? The well depth is 116 ft. , and the hose from the well house to the tank is 100 ft. Thank you again for being so helpful. Robert
