Well For The House Back Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2011, 12:03 PM   #1
Well for the house back up
Hi,
My only source of water is from well and if there is a power outage or if the well motor (Its submersed) goes bad, we will be out of water.
Below are my thoughts to prevent
1. Get a back up power for the pump.
2. Get a back up motor (Not sure how)
3. Get a manual pumping along with electric.
Can some one please advise what I can do here...plss..help me..
mannadiars is offline   Reply With Quote
Old 02-05-2011, 12:08 PM   #2
Experienced
Jackofall1's Avatar
Install a large cistren, to hold water once pumped from the well, this would give a buffer in the event the well dried up or the well pump died, you could then pump from the cistren to the house, this pump would be far more accessible, both pumps would require a backup generator.
Keep a spare cistren pump in the event that is failed.
Mark
Old 02-05-2011, 12:14 PM   #3
Homerepairguy's Avatar
Rewards Points: 998
No experience with well pumps but if I were faced with that problem, I would get a back up power generator. That would not only supply power for the water pump but also for refrigerators, freezer, aquariums and lights. If you have water heating solar panels, a generator can supply power for the circulation pump too.
If you go with a back up power generator, be sure that the exhaust cannot feed back into your or a neighbor's home.
HRG
Homerepairguy is offline   Reply With Quote
Tags
manual pumping , pump , well water
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
What would cause back graded water pipes on a 3 year old house. steveo333 Plumbing 7 11-08-2010 09:32 PM
House gutters flowing back over eaves haveago Roofing/Siding 3 03-06-2010 09:08 AM
help me solve this mystery please lindaberrien Roofing/Siding 17 06-12-2007 01:06 AM
