Well Holding Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-07-2012, 07:37 PM   #1
well holding tank
My water holding tank is waterlogged. The problem is that it is underground. Can I just leave it in the ground and install a new tank in the house?
fixitup1 is offline   Reply With Quote
Old 05-07-2012, 07:39 PM   #2
Please give more details.
jb64 is offline   Reply With Quote
Old 05-07-2012, 07:50 PM   #3
Rewards Points: 14,312
I've never heard of an under ground one like that. Why is is not above ground in the pump house or even in the house?
I've was mine I replace it with a pressure tank.
Old 05-07-2012, 08:27 PM   #4
Rewards Points: 582
never heard of that one....if it is underground ...yes disconnect it and move to house......as said alittle more info...
Old 05-07-2012, 08:47 PM   #5
Rewards Points: 1,548
It would be easiest to install a new pressure tank in the house. Depending on how the old tank is piped, it may be difficult to empty it out in which case it would be almost impossible to lift out and transplant.
For this purpose, get a pressure tank intended for well water systems, not an expansion tank for water heaters.
If the old tank has separate inlet and outlet pipes, it will behave as a cistern and can be left in place and in operation (unless there is a leak which would keep the pump running all day and all night with no one using water.)
The Following User Says Thank You to AllanJ For This Useful Post:
ben's plumbing (05-07-2012)
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
Water holding tank leak Kcornell Plumbing 1 03-24-2012 06:46 PM
questions about plumbing hot water tank bubbler Plumbing 13 01-18-2012 06:43 AM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
Septic holding Tank Settled phillyd2 Plumbing 7 10-17-2007 11:33 AM
