Well Casing Rust - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-31-2013, 06:31 PM   #1
Rewards Points: 208
Well Casing Rust
i posted threads about black flecks coming up from the well. i was going to chlorinate the well today, and saw that the inside casing of the well is really rusty. could this be the culprit of the black flecks and fixture staining?
my original threads:
Well Debris and Culligan Softener
Well and City Water Dilemma
Uploaded with ImageShack.us
Scully is offline   Reply With Quote
Old 05-31-2013, 07:08 PM   #2
jproffer's Avatar
Rewards Points: 714
Looks like every well casing I've ever seen. Not sure about your black specks, but I don't think they're from that. (Opinion of a non-pro plumber who did a short stint as a well pump service tech.)
jproffer is offline   Reply With Quote
Old 05-31-2013, 07:26 PM   #3
Rewards Points: 13,764
Do you also have steel pipes inside the house?
Is there a water softner or a whole house filter?
Old 05-31-2013, 09:05 PM   #4
Rewards Points: 208
there are some galvanized pipes in the crawl space. yes on water softener. no on whole house filter.
my gut tells me that putting bleach down the rusty well casing isn't a good idea.
Old 05-31-2013, 10:44 PM   #5
If you still have steel supply lines a water softners not going to do you any good.
Rust converter (phosphoric acid) not working Studly Automotive Repairs 3 05-02-2013 06:57 PM
How can I get old caulk off after removing door casing? PatrickGSR94 Carpentry 5 03-21-2011 07:15 AM
Need help making a 'back band' around window/door casing. RickDel Carpentry 3 07-15-2010 03:13 PM
Seeking advice on severe rust buildup issue. YerDugliness Plumbing 2 05-07-2010 06:02 AM
Aluminum Casing on Front Porch Pillars DRoby Building & Construction 1 09-06-2009 05:13 PM
